Rear Bumper Question
I`m looking to add a more aggressive look to my 997.1 Carrera S, so I was analyzing installing a different rear bumper and found one NRAuto option. The thing is: I don`t like the 2 bump stops it has, I marked them here
I found the look I want and it would be like this, but the thing is they only sell it for 997.2 at NRAuto
I do not want to change the exhaust setting of my car so something like this would be great.
Do you know any other option? is NRAuto a good quality product? any recomendations? I`m a little bit lost here
Thanks for any advice you could have!!
If you can only find them for a .2 car, you could do a rear bumper conversion where you also switch to .2 led taillights but you will need other parts too, like bulb control module, etc - there's a fairly recent thread where someone who did this listed all the parts and part numbers needed.
914 is on the engine lid as there's not a good place for it on the rear, and it already has the PORSCHE reflector. On the 928 it helps to obscure the ugly trunk lock, and on the Cayenne fills up that large rear panel better.
Some like it - some don't. I do, which is why they're on there.
so in your opinion is this GTG ?
https://www.ebay.com/itm/Porsche-911...y/180905729566
For the white car to be their advertising vehicle, it should be perfect and there are a couple of fitment things that I don't like, however the overall bumper style and design I do like.
- The inward dip where the side of the bumper mates to the fender - good picture of the problem on the left side and I assume it occurs on the right as well, but the bumper is too wide for the rear of the car - my guess... they molded a WB sized bumper and installed it on a NB car since their fitment list shows all models, but the don't differentiate between NB & WB. If you car is a WB, then it might look better once installed.
- Just to the right and below the "a" in "Carrera" there's a deformity in the bumper that creates an irregular gap in the bumper to decklid gap.
When these types of issues occur on a PUR (polyurethane) bumper, they're very difficult to fix. With a Fiberglass or FRP (Fiber Reinforced Plastic) they're much easier and the body shop can build up or sand the area (or both) to reshape how they fit together. The Vorssteiner bumpers on our pink pearl car are Fiberglass, as are all the components from the widebody kit on the Cayenne.
A PUR bumper that's close can be installed by anyone and look OK if the initial shape and curves are good. A Fiberglass bumper can be made to look perfect, but only by a skilled body shop that's willing to spend the time (and your money) to make it as perfect as you want it to be.
For example, fitting of the cayenne fender flares, notice the work they did to make the 3 individual sections at the rear align perfectly (door flare, fender flare, and bumper flare).
The junctions of the front and rear bumpers to their respective fenders have bumper welting (like that used on older 930s & 928s) to cushion the mating pieces which is why the gaps look larger in those areas, but it's the width of the rubber trim that makes it look that way. Here's a closeup of the front bumper welting strip.
thank you for your valuable input and feedback - I appreciate your expertise
