235/35 & 315/25 on C4s
No it isn't. The ratio of tire diameter from front to back is what is important.
305 * .30 = 91.5mm
315* .25 = 78.75
That is too far apart unless you also went with a smaller aspect ratio front tire. But theoretically you could have a 365/25R19 or maybe a 355/25R19 tire and maintain the correct front to rear diameter ratio.
305 * .30 = 91.5mm
315* .25 = 78.75
I don't think you can get wide enough in the rear with a 25 aspect ratio to work with a decent front tire size. What I mean is to get the right rolling circumference with a 25 aspect ratio, the tire gets too wide for the wheel and for the clearance in the wheelwell.
My next set of tires will be 245/35 or 255/35 with 325/30 rear, but I'm running 12" rear wheels with custom offsets.
Isn't 245 front and 325 rear the current 991 GT3 sizing for width?
