Air bag light
Air bag light
Hey Guys, totally satisfied with the way my hood respray turned out. It looks as good as it did coming off the showroom floor.
They did remove the hood to respray it and it was off the car for a good 4 days. I have no idea what they did with the car, but the airbag light in the instrument cluster is on.
To my knowledge, they didn't disconnect anything. I showed up a good hour early to pick the car up and they were still buffing the hood. The hood being off, the light in the frunk was on, and stayed on the whole time I was there. So if it had been like that since Monday..... My android radio did a reset and the time in my instrument cluster was way off, while it is normally dead on.
My research lead to possible low voltage. Please tell me what is the relation between the battery charge and the airbag warning light?????
And how do I deal with this from here???
Thanks for clearing that up.
You need to fully charge the battery then use a Durametric or similar to pull the airbag code and reset it, then see if it comes back. Was your PSM light on too - that's a good indication the battery dropped too low at some point.
Ok thanks. First thing I did when I got home is put the battery tender in the lighter receptacle. As for the code, it will have to wait in the spring since the car ain't going anywhere til then.
