997.2 PCM screen upside down
Old 10-22-2019, 02:22 AM
kellen
kellen's Avatar
Default 997.2 PCM screen upside down
Title explains it all. Left work and it’s upside down. Turned car off and still is occurring.
Next step to pull fuse and/or disconnect battery. Haven’t read about this issue on the forums.
Will update with a fix if it happens otherwise appreciate any assistance.
Popular Reply
10-22-2019, 03:55 PM
Bruce In Philly
Bruce In Philly's Avatar
Received 1,568 Likes on 942 Posts
Old 10-22-2019, 03:09 AM
kellen
kellen's Avatar
Tried PCM reset through the screen, pulling fuse and letting sit for 5 minutes and having car off. Nothing so far.
Next step is to pull battery and let sit overnight.
Old 10-22-2019, 11:59 AM
Astraelraen
Astraelraen's Avatar
Sorry I have nothing to add except I saw this on a jeep once and chuckled
TerrestrialFlyte (03-25-2021)
Old 10-22-2019, 01:36 PM
larrysb
larrysb's Avatar
I've never heard of such a thing - can you post a picture of the screen?
Old 10-22-2019, 02:19 PM
kellen
kellen's Avatar
All buttons work as they should too fyi.
Old 10-22-2019, 03:55 PM
Bruce In Philly
The following 11 users liked this post by Bruce In Philly:
BucketList (03-25-2021), CAVU (03-15-2021), jamesinger (10-23-2019), kru911 (10-23-2019), ManoTexas (10-24-2019), Pilot Sport 4S (03-25-2021), preelude (03-19-2024), street rod (10-23-2019), TerrestrialFlyte (03-16-2021), TheTorch (10-22-2019), Tj40 (03-26-2021) and 6 others liked this post. (Show less...)
Old 10-22-2019, 05:13 PM
kellen
kellen's Avatar
Originally Posted by Bruce In Philly
good idea!
Old 10-23-2019, 05:10 PM
kellen
kellen's Avatar
Bumping this in case there is an answer. Becker wants $950 to fix.
Old 10-23-2019, 05:25 PM
Unframed
Unframed's Avatar
That's crazy. I'm 100% speculating but I can't help but think there is some kind of button combo that flips the display.
Old 10-23-2019, 06:11 PM
platinum997
platinum997's Avatar
Doesn't INFO and OPTION pressed at same time get you into some options.. might be something in there.
Old 10-23-2019, 06:20 PM
jamesinger
jamesinger's Avatar
I would be slightly tempted to leave it like that.
I am very interested in the outcome. This is truly strange and I hav never seen it before!!
One thing that would be interesting is to get another unit, and swap it to see if it is the unit or the wiring before the unit. Lots of legwork though.
Old 10-23-2019, 06:31 PM
speedracerf4i
speedracerf4i's Avatar
I would leave it like that. It's one of a kind, like a collectible item. A misprinted dollar bill will always worth more than its face value.
Old 10-23-2019, 06:55 PM
larrysb
larrysb's Avatar
Huh, well, that's a new one.
Any chance the PCM has been modded, say with a NAV_TV or similar product to allow for a backup camera input?
Old 10-23-2019, 07:00 PM
shyamvenky
shyamvenky's Avatar
From what I scoured in the last few minutes, some Audis have also had this issue - and it is likely the "display ribbon". If you are brave enough to take apart the PCM (like a user did on 6speed to replace his PCM 2.1 screen), then you could just salvage a ribbon from eBay or a dismantler store and just replace that component.
Old 10-23-2019, 11:06 PM
darrenj
darrenj's Avatar
Same thing happened to my screen earlier this year. Shortly after the screen started to roll continuously. I decided to upgrade to a Pioneer headunit so never diagnosed the exact cause.
7 treasures (10-25-2019)
Quick Reply: 997.2 PCM screen upside down
