How to properly maintain convertible top
There is no try. There is only do or do not.
i don’t understand the problem. You operate the top until the clamshell is wide open position and then you stop. Done and done.
I cannot push the rear glass area forward as there are cables on each side. How do I release those cables?
These aren't shown in the images you have. I have a 2010 Carrera, I would be surprised if our tops differ, but maybe they do.
I could not get the rear glass section to lift up either, though the above directions say that a pair of cables need to be disconnected for that to happen. Even without lifting it I still could lube up the top's joints and rubber seals. Might have been easier if the glass was raised but I got by just fine.
Well, I just tried this and honestly, couldn't find a single part that is in the pics above...sigh... even popping off the circular covers near the roll bars revealed something completely different looking, not even close to the pics. but I have an 05 so maybe things changed...
I figured out #2 and #3, but no matter how much I search, can't find anything looking like #1.. Any clues as to where to look? Thanks!
