Launch Edition - please explain
Pete....can you clean this up with what's correct if I went off the rail?
One added value to me is to know that it has the smaller IMS which you can replace. After around late Feb/March they switched, so with 05, unless it is a really early car you never know if you have the small bearing or the large.
Adaptive Sport seats (look for the shoulder wings sticking out the sides) like on my 997 office chair
The PCCB brakes (carbon ceramics), These are yellow and have 6 piston front calipers (look for the 3 piston humps instead of the normal 2 on the Big Red brakes). Rotors also look very different than regular steel rotors, as they're ceramic. They need to be checked very carefully during the PPI for chips in the edges as replacement cost is about $5,000 per rotor new. Look like this.
Only color offered is black exterior and black interior
Also has the Sport Chrono option. Center console should have a "Sport" button and the top of the dash will have the sport Chrono lap timer "wart"
Dash wart in this pics and these are the regular comfort seats, not the Adaptive sport seats so you can see the difference.
See the Sport button 3rd from the left
All of them are S cars, which means the 3.8L motor, PASM suspension, Bose audio, and it should say 3.8 on the airbox in the engine compartment
There is also a special option code for Launch car if you run the VIN for the equipment. I can't remember the code though (might be 030).
Launch cars are a great spec and were sold for a lot less money than starting with a C2S and adding all these options and packages. PCCB brakes alone were an $8,000 up charge, which is why they are pretty rare.
Being early 05 builds they all have the small IMS bearing that needs to be replaced with The IMS Solution if not already done. The upside is that this small bearing is replaceable. The larger bearing used from mid-05 through 2008 is a much better bearing but not replaceable and can still fail.
Good luck. If I was buying another 997, I would specifically seek out an 05 launch car.
