Help About to pull the trigger
Hi all
Hoping to purchase a 2009 4S with 76K. It's about 450 miles away so had a PPI done by the Porsche dealership.
Did a quick search but on a time schedule as I am at work and hoping to negotiate down the price.
Not sure if these are common problems and if it's expensive or DIY repairs (i.e. is it just plugged?). They didn't do diagnostics nor am I next to the car to check myself.
Hoping to fly out Saturday to pick it up, but have some more negotiating to do.
1. HVAC re-circulation not switching
2. One of the headlamp washer isn't working
3. Window Washer isn't working (don't know if there is motor noise or not). I know the original dealer/owner (it's on consignment) original tank was empty, currently full, so could just be clogged with debris?
4. right front door switch
Had been up to date for most of its life (dealer records) but all the 4wd/ PDK/brake fluids need to be replaced. FYI, Porsche fluid is expensive, who needs fine wine.
Needs "major service" which seems like sparks plugs and oil (which is up to date) and lots of checking. (which was just done)
Serpentine belt glazed. few other odds and ends
rear brakes at 5mm, will need soon.
But mechanically and cosmetically looks great per dealer.
Have the dealer quotes for the diagnostic top 3, but obviously no repair advice.
Thanks in advance,
Hope to join the club
Cheers,
Brad
Thanks in advance,
Cheers,
Brad
Whats the asking price? What are the options? Im guessing 36-38k with those problems
Window washer might be simple fix with just hose coming loose under the plastic tray where the nozzles are. Happened to me.
Asking 39,900
Cabriolet
loaded
PDK,
heated/vented seats,
blue tooth
navi
Sport Chrono'
High end Bose
steering wheel controls
Universal audio
Bi color int, crest etc.
Pwr comfort seats both
Black on Tan
Cabriolet
loaded
PDK,
blue tooth
navi
Sport Chrono'
High end Bose
Universal audio
Black on Tan
2 & 3 are super easy cheap fixes. Not sure on 1 & 4 and those are not super common. The bigger question I would have is why are so many easy/cheap maintenance items neglected. If the person neglected standard easy to see items what else was neglected and how was it treated when driven.
Rumor has it, he and the car live in Florida where the car spent most of its life then made its way north where it is used when he is in town.
Car fax shows low mileage the last three years.
I tend to look at it similarly.
I'm not big on purchasing a Porsche thats missing several different services and/or has a number of small issues to address. Just seems like the previous owner wasn't too careful about taking care of it. I'm not saying my Porsche purchase needs a spotless car that needs nothing. But it shouldn't be a number of small/cheap/easy fixes that were neglected as well services that were not done.
"cosmetically looks great per dealer" is the most subjective I think.
Also I don't think a Serpentine belt feels like a "backburner" item if it's visibly worn out? you might be looking at 2-6k with brakes and that list, just my .2 cents.
You folks are tough! Not everyone is as **** as we are about car maintenance. If the major items are attended to like oil services, water pump replacement etc, I would not hesitate if it was a car that I liked in terms of options and colors. If you are inclined to do your own service, these things can be easily handled and done affordable. You might be able to negotiate down a bit due to the brakes. 5mm is getting close, particularly for Porsche brake system. I had a few minor things that were needed on my car and the previous owner was very good at maintaining the car. I actually enjoyed fixing and addressing the items as I bonded with the car. Just my two cents.
Appreciate the input!
Currently can get for around 36,500. Voiceprint1 is correct. Will need about 6K to bring up to date. Hope to do some of the hardware stuff myself and maybe the spark plugs to save some money (talked with SA about the serpentine belt. it is okay (no cracks) but is definitely on the short list of what needs to get done)
But Would then own a heavily optioned (see above) Gen 2 4S Cabriolet that is up to date on all its maintenance with new rear brakes. Though the tires are at 06 mm and will need replaced soon.
This will be a weekend, second car so could walk away.
Thanks for everyones advice.
Love to hear what you think of the price or just walk away etc.
