What's it take to get a 997 C2S to handle like a GTS?
Hi guys. I'm new to P-cars and just purchased a 07 997.1 C2S. Its already got Ohlins coilovers on it already. What other suspension components would you guys recommend I get to make it handle like a 997 GTS? Also, what alignments specs would you get for 75% track/25% street use?
My understanding is that the gts is a C(2/4)S with options pre-included, only extra things are the widebody and the powerkit which might have been an option too. I believe the gts has sport PASM suspension, or the fixed rate sport dampers. All of which should be optional on a C2S.
Hopefully someone with a gts will chime in soon.
I don't doubt you could make any Carrera handle better than a stock GTS. The stock handling of all Carrera is more setup for tame street driving, therefore if you put some thought and work into it I imagine even a base Carrera with modified suspension could have better handling than a stock GTS. But getting it to handle like a car with a slightly wider rear track (44mm) may not be possible. I'm not sure the difference would matter, once you get it dialed in it'll be awesome either way. I believe the GTS comes stock with a slightly thicker sway bars. Besides that and the slight difference in rear track width I can't think of any other suspension that is different from a 997.2 Carrera S. Well PASM is standard, so that will be one difference though OP already has coil overs. GTS that have Sport PASM (which you can also get on a Carrera S) will have an LSD... so that would be one moderately big difference, of course not all GTS have Sport PASM.
Interesting discussion on 997 GTS suspension.
https://www.edmunds.com/car-reviews/...e-911-gts.html
edit:
found a thread with a bunch of info on this very subject;
https://rennlist.com/forums/997-foru...ech-specs.html
edit:
What are deficiencies that you are trying to solve? Who says that GTS "handles" better whatever that means? Zero difference with placebo effect for X51. I can tell you if you are really advanced driver after 4-6 years of track driving you could do a few things to make your driving experience easier on the track. Get DSC box for PASM and get adjustable sway bars. Leave stock shocks and springs along.
Invest in professional instructing, mentoring, and more safety equipment.
Only differences between .2 c2s and gts suspension are a bespoke front sway for the gts, revised PASM control module and the rear track width. The only thing that makes that track wider on the gts are the rear wheel sizes and offsets. They use the same half-axles (body is wider obvi but we’re talking suspension).
Thats it.
you have .1 which only has two axis accelerometer for PSM. So a little inferior electronics if you went passive suspension but not much.
If you are 75/25 track/street you need more that old man ohlins. Check out my thread. That’s how I use my gts.
Thats it.
Thanks for the links. Definitely helps me
to understand how far advanced the GTS is. Now time to take focus off that and to focus on learning this car and driving it more.
My other track car is a 93 Mazda RX-7. I’ve yet to take my 997 on track so before I jump to start modding, it’s better for me to figure out what I’m trying to address with it’s handling.
edit:
edit:
OT. I drove an FD for 15 years, got it in '92, sold it in '04, bought another, sold it in '06. Took the first one from it's 255 hp to 400 hp, the second one was already set up. Great car!!
Had the FD while I also drove a 996C2 (tame in comparison), then a 993TT, then a 996GT3. Sold the second FD while having the GT3. Drive a 997GTS now.
More FD talk.. thats one car I could never get out of my head. Always wanted one, still do. Finally got to drive one last week, and it was all I hoped it would be. Also a GTS driver. Maybe I'll be able to get one at some point.
if you still need better handling, look into adjustable sway bars and drop links (tarrett)and rear Dog bones kit.
next step will be corner balancing the car. I’m assuming you already have good tires on the car, if not get the cup 2 first as that alone will provide a significant difference in handling.
You definitely should if you have the chance. They are incredible machines. I’m currently having a new motor built and installing a new turbo kit. I should be at close to 500hp to the wheels.
Driver training and Geo set up. You may have a thousand track days under your belt, but a better bang for buck result you will not find. All my mates who were former pro racers were constantly training and assessing. They have far more data st their finger tips than you or I will ever have, but they're still training and improving technique.
There is plenty of adjustment in a std 911 to make great gains in car handling.
If you are predominantly going to track the car, is have thought you'd be looking for a GT3 setup rather than GTS. A tad confusing.
Save your cash on hardware and better yourself and adjust the car accordingly with what you have.
