Topgear center muffler bypass for 997.2
#76
#78
Originally Posted by mdfud;[url=tel:17395553
17395553[/url]]I did not remove the bumper on my 11 C2S. I was not able to see where removing the bumper would have helped and I didn’t want to risk mucking up the rear camera.
#79
Installed the Topgear center bypass today without removing the bumper. Thankfully my car spent the first ten years in Beverly Hills and two years in Washington since I’ve owned it, so all the bolts came out with relative ease. The top cat bolts were a little tough to get to with the socket. Swivel socket with a little finesse and they were out.
The sound has a little more growl to it but not loud at all. Pretty happy with it and I always enjoy some wrenching.
997ajk (05-02-2021)
#83
Originally Posted by 997ajk;[url=[url
tel:17406037]17406037]Any[/url] noticeable power difference? Weight and quality?
#84
After the install, do you guys experience increased vibration on the steering wheel when stopped at lights? I have a PSE permanently on fyi..
Also the tailipipes seem to be vibrating a lot when in Park.
#85
I don’t have any additional vibration after installing the Topgear x pipe with Fisters. If anything, I actually have a lot less vibration after install, even with upgraded Function First motor mounts. Perhaps you should check your bolts and make sure the exhaust system is not contacting the rear bumper or heat shield.
axl886 (06-11-2021)
axl886 (06-11-2021)
#89
Ok, it was bothering me the whole night so I drove down Sat morning to re-tighten everything, they insisted everything was fine.. no reason to doubt them as they're quite a notable Porsche indie. But the vibration is still there.
My car is PDK, 127k km mileage. The vibration is felt thru the steering mostly, but i think the cabin is feeling it too. At Park or Neutral, there is none.. only at 1st gear when stopped, then it appears. When being driven, there isn't. My question is: might it be my old engine mounts?
