3rd radiator on 997.2 GTS
Anyone installed a 3rd radiator on a GTS or aerokit?
Suncoast says additional parts may be required, but when I called they weren’t sure what I was talking about...ordered the radiator, I just don’t want to get halfway into the install & not have what I need.
Suncoast page: https://www.suncoastparts.com/mm5/me...D&Store_Code=P
I installed the 3rd radiator on my 2012 Carrera S using the following parts. MUCH CHEAPER than the kit from Suncoast and exactly the same parts. I have a 2011 GTS and this would work on it as well.
For the 997.2 you need this in addition to the radiator kit:
AIR ROUTING 997-575-141-07 $139.80
RADIATOR 99704410005 (The Kit) $173.22
SunsetPorscheParts.com
Easy installation
Easy installation
Easy installation
Easy installation
May want to search "997 radiator add-on" on ebay. Hoses/radiator are the same between 997 and 997.2 from what I can tell, its just the ducting. I picked mine up in the $200 area
https://rennlist.com/forums/997-foru...997-1-set.html
Unless you race it on a regular basis, I wouldn't bother. The stock system is fine.
I got a kit for my 997.1 S for $180.
I thought all GTS came with 3rd radiator. This is the first I've heard of anyone with a GTS asking about this mod or wanting to do it. Mine came with a 3rd radiator.
My car is a manual, originally sold in WA...so no 3rd radiator ☹️
Ah, yes, PDK!!
BTW, a definite plus on that 3d radiator. Three of us regularly go out together, my GTS, a PDK C4s, and a manual C4S. I constantly run 30-40 deg cooler when we're running hard.
So I did.
Says it's now $201 https://www.ecstuning.com/b-genuine-...n/99704410005/
As y'all know, there's two separate 3rd radiator kits for the .1 and .2 Carrera models. Here's some photos from ECS as an example...
997.1 Carrera models ($202) - https://www.ecstuning.com/b-genuine-...n/99704410005/
997.2 Carrera models ($885) - https://www.ecstuning.com/b-genuine-...710603702kt10/
Some parts (e.g. the radiator) is the same in both kits. But the ducts are different.
997.1 center air duct ($100) - https://www.ecstuning.com/b-genuine-...t/99757514102/
997.2 center air duct ($187) - https://www.ecstuning.com/b-genuine-...t/99757514107/
However, that doesn't explain the $600+ price delta between the kits.
I'm a bit mystified...
Karl.
Karl.
