RADICAL Oil Change! Cold & 9 Quarts!
I've done both my diesel truck and 911 when cold in the morning and been able to get out much more oil that way. And no hot oil burning my hands was great. I've since gone back to changing after slightly warmed up. Partly for the reasons Petza states above. But mostly because of concern for lack of lubrication during cold start. Warming first pumps up the hydraulic chain tensioners and throws a coat of oil on the valvetrain before shutting down. After changing the oil and filter there is a delay in oil pressure immediately after starting. Most engine wear on street driven cars takes place during the cold start procedure.
Good points for a one hour drain, but probably less so if you drain overnight. In either case the oil filter has to refill. I believe a residual film on the metal parts has a good retention time. I'm not sure about the chain tensioners and what happens during the drain period, but curious.
I'm not seeing the difference between draining the oil overnight and letting the car sit overnight (or in between drives). Either way you have a crankcase full of oil and a drained motor.
OK ... The difference is oil in the filter. When I used to wrench for a living I'd prefill the filter during a change to avoid start up starvation (when possible). Someone much smarter than me pointed out that the fill time was insignificant. I don't do this anymore.
I agree that primary wear occurs in the first few miles of driving. That's the time to take the most care.
I also agree we are a bunch of OCDs!!! But there are enough of us that we must be right
Isn't the computer smart enough to prime all tensioners etc? All it has to do is delay ignition by a slight turn of the crank.
Regarding residue settling out of the oil..... um.... I am not so sure about this. The oil filter takes out anything bad. The oil in our sumps is actually fairly clean of damaging chunks. The microscopic stuff still in there is in suspension. Otherwise all the black stuff would settle out and the oil would be clear again. Did anyone actually see this happen? Anyone see sludge at the bottom of a spent oil jar? It sure doesn't in the spent oil bottles I have gathering up like a military waste dump site. Besides, 8-9 quarts of oil flowing quickly out that hole does some pretty good agitation of its own.
How much went in...... About 9 quarts. Hard to say exactly because I had a 5 quart bottle with an odd small amount in it so I had to open three 5 quart bottles. Now the gauge reads one notch below full. My typical fill process is put in less than came out... or more to the point, target a low gauge reading. Then I drive it around until hot, then read and top up. Even then I don;t top up all the way.... every other fill, I can get some goofy inconsistent readings so I don't want to over do it. Usually I top up again a few days later. We are talking about small amounts... I like to get it all the way up or one notch down as it is now. I usually add when it is below half.
Peace
Bruce in Philly
Peace
Bruce in Philly
It takes some time for the heavier sludge like component to separate out of the oil. I see this all the time when I empty my oil extractor from my boat and there is a thick black residue left on the bottom of the extractor when emptying it out ......But I have not ocd analysed it, and its usually at least a couple of weeks later
Peace
Bruce in Philly
Peace
Bruce in Philly
