Video review of the Foxwell NT510 with Porsche software...
#91
received my NT520 PRO today and spent sometime with it. It already came with the latest porsche software and there was no other update available for it when i checked.
On a 997.2 C2S PDK, it does not reset service due light, it does not read over revs. It shows engine hours and mileage on DME in KMS. Airbag light reset is possible. Steering wheel angle sensor re-calibration is also possible.
I will update if it will cycle the abs pump and i did see a transmission fill mode (for pdk?) but did not try it out.
It will also read all codes which cheap obd bluetooth adapters paired with Torque app wont even rear or clear.
#92
#93
possible bu5 if you connect a genuine piwis tester at the Porsche dealership it will show the over revs for a pdk as well.
#94
So if I'm reading correctly, this cannot clear oil/maintenance reminders? Is there another unit that can? While I think it's neat to program all of the other things, I can't see buying one if it can't do the basics.
#101
If I understand you correctly, you have not downloaded the Porsche specific software from the www.Foxwelltech.com website, at which point a Porsche icon comes up on the display which enables access to the various diagnostic/setting functions.
#102
icarsoft por2 can reset service lights
Though I still check regularly for updates, hopefully one day in the future will be able to. Until then I will read service due every time I start my car
#103
#105
Anyone tried disabling TPMS with NT510 or NT520? I understand the TMPS control box has to be disconnected first before starting the disable process. Been having problems with TMPS system again (sensors are only three years old) and fed up with false readings.
