Video review of the Foxwell NT510 with Porsche software...
#61
My '06 C2S does have seat memory, but the passenger's side mirror only tilts down in reverse when the mirror adjuster switch/**** is set to the passenger's side mirror. I'm not sure if this is documented anywhere, I just happened to notice it one day.
#62
Went ahead and activated the drivers/pass door open/close functions and PAS was already enabled. Now when I hold the lock/unlock button to unlock the car only the passenger window goes down. With both windows down if I leave the car and hold the lock/unlock button only the drivers side goes up. Anyone else have this issue?
***Solved***
Apparently somehow drivers down and pass up defaulted to off so I just had once again reprogram to on. Problem solved.
***Solved***
I've made it a habit to always re-read the settings for the module I have just completed coding, as I've noticed the NT520 will display the setting of your last coding attempt, but the coding doesn't always seem to actually take affect.
#65
#66
#67
Thanks to user BaileyII I have confirmed the horn honk on remote locking can be enabled as well! I have added this info to post #34 as well.
#71
I did the above and it didn’t work for me now my alarm is silent plus I can no longer see the “Customer Specific Setting” setting under “rear”, it disappeared. I guess I accidentally disabled the horn for the alarm. I’ll have it reset by the dealer if I can’t find a way for the NT-520 to read “rear” and give me the "customer specific settings" choice again.
#72
#73
When I go back to the "Rear" section I get a "that function is not supported" message and not the "Customer Specific Setting" but when I checked for error codes under "Rear" I got a "8061-Siren communication" error code. I'm not saying it's the fault of the device it's a mistake on my part even though I was careful.
I have a 997.1 and using the latest software in the device, I still have a sd card with the original software so I'm going to put that one in the device and see what occurs, I'll keep you posted.
#75
Glad the Durametric was able to get your "rear" section back again. So strange that caused an issue for you, but at least it wasn't a trip to the dealer.
