Oil leak at or very near oil filter (using LN engineering adapter)
Old 01-04-2018, 11:19 PM
  #31
scottiemac
scottiemac's Avatar
I had an L&N adapter on my 996 and had no issues with it. When you had the adapter off did you check the O ring very carefully to make sure it didn’t get pinched during installation? I think the O ring is the same as the one used on the factory canister so you might pick one up at the dealer and try refitting it.
Old 01-05-2018, 06:30 AM
  #32
Charles Navarro
Charles Navarro's Avatar
Received 1,071 Likes on 557 Posts
Spot on. The o-ring on the spin on filter adapter is the same as the factory filter canister o-ring. The o-ring might be torn or have a defect, however, I'd rather the unit be replaced with a new one to ensure leak free operation in a case like this, since leaks are not very common.
Old 01-06-2018, 02:37 AM
  #33
ALEV8
ALEV8's Avatar
No problem with mine either. Thanks LN!
Old 01-19-2018, 06:47 PM
  #34
rodH
rodH's Avatar
Just a quick update. After I mentioned the 2nd time that it was still leaking, LN reached out to me and offered to send me out a new one, no charge, next day air. I declined and told them to just send it slow boat, as I know how expensive next day air is. Sure enough, next day it arrived. I have only driven the car 3-4 times since so I dont have any definitive answers, yet. What I can say is that the part went on much more "snug" which tells me that it is sealed better and so far there are NO leaks, what I can also tell you is, how awesome LN was in send this next day air to fix a problem. I would have NO hesitation in purchasing anything from them in the future!!!
Old 01-26-2018, 11:31 PM
  #35
malexgcab
malexgcab's Avatar
Old 01-27-2018, 05:09 PM
  #36
sober_owl
sober_owl's Avatar
wouldnt you just need new o rings? arent they replaceable?
Old 01-28-2018, 01:11 PM
  #37
Charles Navarro
Correct. The spin on filter adapter uses the same o-ring as the factory filter housing.
What happens is that if the filter adapter does come off the engine, the o-ring should always be replaced. That's why when you buy a filter cartridge for the stock housing, that an o-ring is typically included so that you do not re-use the old one.
That said, the only time we have seen these leak is if the o-ring is re-used or somehow damaged during installation (or re-installation).
Old 01-28-2018, 03:05 PM
  #38
lowbee
lowbee's Avatar
When ordering a new spin-on adapter from LN, does it come with a fresh o-ring ?
Old 01-29-2018, 10:13 AM
  #39
Charles Navarro
Yes. The spin on filter adapter comes with new o-rings pre-installed.
Old 02-11-2018, 06:18 PM
  #40
doclouie
doclouie's Avatar
So not to hijack the thread, but how do you fill the oil filter with oil, as recommended, and then turn it upside down to install it on a 997.2 without making a mess?
Old 02-11-2018, 06:42 PM
  #41
Petza914
Petza914's Avatar
Received 6,172 Likes on 3,936 Posts
You can't. That's only for .1 cars. In fact, LN doesn't make s spin-on filter adapter for any DFI Porsche fitments. Wish they did.
Old 02-11-2018, 06:47 PM
  #42
doclouie
doclouie's Avatar
Thanks for not flaming me. I am new to this car. Paper filter it is.
Old 02-11-2018, 10:01 PM
  #43
Charles Navarro
After requests, we did make one for the 987.2 and 981 (with MA1 engine) Cayman and Boxster. To be honest, it's not as popular as the MA1 engines have historically had less problems so owners aren't as concerned about changing from the factory filter arrangement.
Quick Reply: Oil leak at or very near oil filter (using LN engineering adapter)
