Front struts going. How easy to replace DYI?
My front HOOD struts are pretty much shut. How do I replace them myself without causing any damage to the screws on the hood, etc.
thanks
thanks
- Remove brake caliper and tie off to the side.
- Pop the outside tie rod off the carrier.
- Remove bolt from lower control arm (wishbone) at cross member.
- Remove bolt from forward control arm at cross member
- Remove drop link at strut. Be careful the carrier could fall right off strut. It likely won't though because the wishbone and forward control are need to be wiggled loose.
- With the carrier removed you'll want to mark the location of the three strut studs/bolt in the frunk area. Then loosen them carefully and pull your strut and spring out.
- I think you can take it from here.
If you put everything back together correctly you probably won't need an alignment. Worth getting it checked though.
Now on a C4S I don't know if the carrier pulls off the drive shaft. I think Pelican has a DYI and shows it.
Thanks, but I mean the front struts for the frunk
I wasn't clear at all, sorry!
These guys... https://www.suncoastparts.com/product/PK997STRUT.html
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
alexb76,
Simple DIY job. The struts have ball sockets on the ends, so they just snap off and on. Will not take you more than ten minutes.
If only most other DIY projects were so easy.
Thanks guys. Just got the parts from sunset. There are 996 instructions online, do the 997 works just like those? A clip that comes off and snap in place?
https://rennlist.com/forums/997-foru...l#post14554362
