Engine oil failure warning
How many miles? I bet you this will be the next fricking thing to puke on my car. This or MAF.
I had the same failure, it actually was my fault when I did an oil change. Was mopping oil up in the filter housing with the filter removed. Used a paper towel. Quit sometime after the oil change, I started getting the same failure you noticed intermittently, then the failure stopped. Next oil change removed the filter to mop up the residual oil, thats when I saw a very small piece of paper towel by the sensor area. Removed it and never had another issue!
Lesson learned use a lint free cloth to mop up the residual.
of all the cels to get ( a bright red heart stopping oil can!.. perfect! .. ).. all for the twist of a couple of connectors. hope i never see this. but at least i'll know what to look for.
