Engine oil failure warning
I got a picture of a oil can failure warning and a beep, as I was driving. I didn't notice how many bars of oil pressure b/c it happened so fast, then warning light went out. Oil pressure and level are normal now.
Does this sound like a failing oil pressure sensor?
The best way is to lower the engine. And it can be done with a floor jack under the crankcase , you remove the two nuts on the aft engine mount (19mm deep socket) and you release slowly the pressure on your jack until you got about 4 inches. It will give you some space to remove the transmitter (or sender).... The torque for the engine mount nuts is 63 foot pound....
Thanks!
