996 Turbo Forum 1999-2005
Best replacement battery for a 2002 TT?
Old 11-12-2019 | 10:21 PM
  #46
ENV's Avatar
ENV
Originally Posted by Kevin
94R or H7.. The H8 will fit with a little rework..
I dislike the newer Interstate batteries>> they don't last as long as they use too. For mild climates they might work well. I would prefer the US made East Penn units (thus my opinion based on how many dead Interstates I have pulled out).
Your thoughts on this one? Looks like it's the type needed. Height seems tall though.
https://www.diehard.com/products/die...-with-exchange
also this one but autozone webpage states it doesnt fit my vehicle. You have any thoughts on Duralast?
https://m.autozone.com/batteries-starting-and-charging/battery/duralast-platinum-battery-h7-agm-group-size-94r-850-cca/319458_0
I may go to Pep boys and just get the Bosch as I cannot find a vendor for East Penn. Any idea where I could order one?
Old 11-12-2019 | 10:43 PM
  #47
Kevin's Avatar
Kevin
It will fit>> it is a East Penn manufactured with a Diehard label on it
Old 11-13-2019 | 12:02 AM
  #48
Antigravity's Avatar
Antigravity
Premium Sponsor
IF you are interested in Lightweight Lithium Battery then we have something to check out... Antigravity Batteries. https://antigravitybatteries.com/pro...es/automotive/
- 8-10 year lifespan,
- WIRELESS Built-In Jump STarting so you will never come back to a dead battery again... Even if battery drains you will not be left straded... just press the provided Wiresless Keyfob and start the car, and drive away.
- Weighs 30lbs less than an H6 battery and up to 37lbs LESS than a 94r (group 49)
- 2x the cranking Power of a similar sized LEad/Acid Battery
- Drop in OEM fitment... not need to modifications fits in using existing mounting.
Old 11-13-2019 | 01:31 AM
  #49
911mhawk's Avatar
911mhawk
Originally Posted by ENV
Any updates to best battery for 996TT. My battery is on its way out and I want to replace it before it really dies. I am hearing AGM is better and 790 CCA. Any issue with a heavier CCA battery? Also what's the best one to fit without modifying anything but still more potent? Only the one mentioned above?
I've had no problems with the Anti-gravity ATX-30 for the last year:
https://rennlist.com/forums/996-turb...battery-2.html
The car sat most all last winter ad car started fine every week or two, no drama.
Had to jump once when I let it sit for over a month but then drove 30 minutes and it was fine.
Less issues than I had with a two year old Interstate, that one would make my radio/CD player act up ad loose settings, AG battery has not done that.
Old 11-21-2019 | 02:14 PM
  #50
ENV's Avatar
ENV
Kevin I cant find that other diehard battery.
How about this one? Will this fit without modification? Any ideas on Optima batteries? Used to run them 10+ years ago
DieHard 50748 Group Advanced Gold AGM Battery GP 48
  1. "><img src=" /> ">
  2. "><img src=" /> ">
  3. "><img src=" /> ">
  4. "><img src=" /> ">
  5. "><img src=" /> ">
  6. "><img src=" /> ">
  7. "><img src=" /> ">
Quick Reply: Best replacement battery for a 2002 TT?
