Filter wrench size
Mangling the plastic cap is usually a result of not seating the filter socket all the way down before applying torque, causing it to slip off. I found seating it all the way and only then inserting the 1/2 socket wrench prevents this.
BTW, Mercedes uses the same size.
74.5mm is correct, but some '76mm' fit excellently and are probably more widely available, all depends on the variance in the tool
My '76mm' Jet Tools wrench fit perfectly on both Porsche and Mercedes filters
I just got this one. Amazon prime, tried it last night and it fits perfect. I had ordered a 76mm and it did not fit properly.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
https://www.pepboys.com/product/details/293978/00221
Likely available in your local pepboys for cheap
