Leaky part
The important thing to remember is to hold the red retainer towards the tank while pulling the hydraulic line. To do this you can get an "air conditioning and fuel line disconnect tool". I stay away from anything in metal because a scratch on the line while pulling it and a possibility of leaks! Also, if you damage this red plastic retainer it is very difficult to found one on the market. But if you ever replace your slave for a new one keep the retainer! It is exactly the same type installed on your power steering pump. Also keep the o-ring in the back!
You were lucky. Because it seems sometimes when you pull off the low pressure hose the crush fitting where the hose steps down to the nipple fails and leaks.
With my car when the low pressure line was removed from red retaining ring in the pump the stress of getting it out caused the line to leak at the point were the crush fitting of the rubber line steps down to straight tube with plastic sealer coating on it. Does that make sense?
There have been others here with that have had the same issue.
Here are what the power steering lines look like on my car. You can see the top low pressure one. Right where the silver crush fitting steps down to the black tube is where it was leaking.
Carlos had a hydraulic hose failure on the crimped fitting. This usually occurs if Pentosin has leaked on the hose. AND if the engine is not supported correctly when removing an engine OR lazy tech when changing the clutch. The line takes the stress when the engine is lowered.
This hose is becoming a wear item. The plastic coatings on many hoses have been scratched and dinged. I have seen RTV silicone used in attempts to seal/repair the suction line.
I guess that this is another TOO LOOK ITEM when doing a PPI.
It is not available. The green Viton oring withstands Pentosin
With that said any hydraulic hose repair shop might be able to supply the green Viton..
As JP mentioned, find someone that has an old SLAVE that they just replaced..
It's all done now (got the car back yesterday), with a part I'm not sure will withstand Pentosin on the long run.
So I'll take your o-ring JP, I'm sure it will give my some headache again soon or later. PM sent.
Just went to look at the slave I took off from your car. Unfortunately the red retainer is not in good shape but the o-ring is perfect! I will send it to you tomorrow morning. You should get it at the beginning of next week...
