Redline
Thanks for the info Ken. That info really helps! I'm good... keeping busy tricking out my wife's SLK. For the price of a GIAC chip, I can do every single mod in the book available for the SLK.
Back to my original question before I was rudely interrupted by Ken. ;-) Does anyone know the redline RPMs in the forward gears?
Thanks.
Thanks.
Keeper of the Truth
Re: Redline
Originally posted by skaria
Is the redline of the 996TT 6600 RPM in _all_ forward gears?
"The beginning of the red marks at the right end of the scale indicates the maximum permissible engine rpm."
Since the engine spins using all forward 6 speeds and reverse, this statement applies to all 7 gears.
No, the only reason why I was asking was that I got cut off a couple of times at a little past 6000 in first gear recently while the other gears were at the red mark on the tach. I never really look at the tach when I drive in the street and I only looked recently because I hit the rev limiter.
Thanks.
Thanks.
When accelerating at WOT in 1st gear, I initiate the 1-2 shift at 5800-6000 RPM...maximizes the power and provides much smoother shifts, since trying to shift smoothly once the limiter engages is just about imposible.
