NHTSA - looking into coolant pipe leakages
#46
the idea of using an inserted coolant pipe(into casing) isn't a horrible idea, but would have been much better if using a 'sealant' with a support(ie.pinned, retainer, screwed-in pipe fitting, etc) rather than a structural adhesive/sealant used on a performance-designed car which sees many, frequent heat-cycles
#47
A well-designed casting or weld using proper metallurgy is considered lifelong(didn't mean as-in non-finite)...as in lasts longer than the user does; I'm gonna bet my GT2's engine case will be structurally solid long after I'm in the ground, but the sealants used to contain its fluids will leak and give out
Modern adhesives are awesome for certain purposes, but ALL have a finite life, and it is most often much shorter than 'lifelong', and is engineered to 'fail' within a certain timeframe
#49
I'm not talking BS here, anyone can do the research themselves if they want to prove right or wrong...my 'opinion' is based on real-life experience as well as my own research, and from my family's background in engineering and chemistry
I'll be either pinning(along with a suitable sealant) or welding mine soon...I'm not waiting for a magic adhesive to replace the current adhesive
Cheers,
Cheers,
#50
#51
I'm not trying to anger anyone here, just stating that as wonderful as modern adhesives are, we shouldn't rely on them completely...
#54
#56
http://www.specialchem4adhesives.com...l.aspx?id=2360
http://solutions.3m.com/wps/portal/3...ons/Adhesives/
http://www.permabond.com/en/en-conta...=cyanoacrylate
http://www.cotronics.com/vo/cotr/ca_metallic.htm
http://www.henkelna.com/industrial/m...ives-13573.htm
http://www.firesleeveandtape.com/hig...sket-seal.html
#58
Dock, those all look like great adhesives/sealants/fillers, but they all still have a limited life-span, words like 'long-lasting' and such terminology is used indicating it might be a great product but is still not expected to last 'life-long'.
The space shuttle keeps being used as a halo example for adhesive use, however it is rated for up to 100 launches within 10 years 'operation life', perhaps due to the 'unknowns' of adhesives????...adhesives can have properties of strength in servere heat and vibration, etc usage, but I have yet to hear/see/know of any product which claims to 'completely' resist the effects of aging/atmospheric effects
Just don't want anyone using a 'new' adhesive on their coolant pipes thinking its a guaranteed 100% structural fix and have them blow out and cause an incident/injury to themselves or anyone else
#59
When I designed an addition to my house, the engineering showed that a single LVL beam would meet the load requirements; however, I wanted to make sure the flooring that was going to supported by the beam would not have any movement, so I installed two LVL beams. This is what's called "muscling up" (stronger than needed), and it is a strategy that in many cases extends the initially calculated useful time. So in the Turbo's adhesive case, this would be like Porsche using an adhesive that exceeds the calculated stress, temperature, and stress requirements that were initially calculated. So assessing a particular adhesive in any of the links I provided has to be done within the framework of what the initial target calculations were for the coolant pipe connection was. If an adhesive exceeds the engineering requirements, then in many cases the longevity is increased.
I'll also say, again, that I no one has shown any data that indicates an unmodified and street driven (non-tracked) 996 Turbo has coolant pipe connection failures of any kind, and more specifically, catastrophic failures of any kind.
#60
Well the NHTSA has opened an inquiry. I am hopeful this will be investigated and data will be needed to substantiate any actions. Just because no one has given YOU any data, does not mean it doesn't exist.
