Anyone have issues with cracking of Girodisc 350mm rotors?
Anyone have any issues with cracking of the Girodisc floating 350mm rotors? I'm wondering if this was a manufacturing defect in the steel as the other side did not crack even though it is worn to the point of the slots beginning to disappear.
http://www.flickr.com/photos/87731073@N06/8196475187/http://www.flickr.com/photos/87731073@N06/8196475187/ by http://www.flickr.com/people/87731073@N06/, on Flickr
Below is a picture of the right front, just small surface cracks in that one and it's worn down even more.
http://www.flickr.com/photos/87731073@N06/8198930937/http://www.flickr.com/photos/87731073@N06/8198930937/ by http://www.flickr.com/people/87731073@N06/, on Flickr
I have managed to kill a set of RS6Plus discs set ( 8 pots RS6 calipers) in one track day on an RS4....If outside temp is high and the track is small with no much long straight , brakes can't cool down. How do you brake ? I brake hard really late . 996 tt and 996gt2 are still on the heavy side and really pished hard the brake will take some hammering. Have you try Alcon rotors, many people use them on Gt3's and other models other here in europ, it seems really good for track use.
Still plays with cars.
All rotors crack eventually.
Those with holes, sooner than slotted but slotted rotors will crack after enough hard use.
Try one cooling lap in the middle of a session it can help a little bit to extend their life....
100% agree with that . Try the Alcon to see what they are like. These cars are heavy and to be honest not for proper track use , if you plan to track it a fair bit you need to expect replacing rotors often I am afraid.
Yeah, it makes perfect sense now especially considering that this past weekend temps at the track were pretty cool in the upper 50s so I was really pushing some very cool air over very hot rotors on my cool down laps. I see how that may have played a role in causing the crack.
