EVOMS GT2 slave kit v. Drill/Tap method?
Since my engine and transmission is going to be out I was planning on having the EVOMS GT2 slave kit installed. I've seen write ups where guys have drilled and tapped the gearbox and installed the slave in the same location as on the GT2/3 which would also require purchasing a new clutch fork. My question is, from a function or durability standpoint, is there any difference or advantage in performance by doing the dril/tap method v. the EVOMS kit which has everything including the lengthened rod? I'm trying not to overcomplicate things.
Thx....
Thx....
Issues is discussed at the tail-end of this thread. Some pics of drill/tap.
How do you know that your Fork doesn't need to be replaced? Strong chances that it does need to be replaced if you have over 50K on the clock.
