wont stay running
wont stay running
Guys any help would be greatly appreciated. I live about an hour tow truck drive to my mechanic so any help to avoid that flat bed charge would be appreciated.
The problem: car wont stay cranked. It starts idles for about 2 seconds then dies. If I apply light throttle I can keep light pressure on the accelerator I can keep the car revved in the mid rev range. If I try to apply throttle abruptly while I have it in that range it dies. If I try to let the idle settle it dies.
The car: 2001 Turbo. 6 speed, mods lwfw and clutch, ImagineAuto stage 4 car, Evo 5 intake (no MAF issues), EVO DV, upgraded turbos, silicon hoses, yada yada yada, 62K miles, did all new COPS and plugs at 45K.
TIA
Lane
TIA
Lane
My guess: Fuel pump problem. There is a weakness with our fuel pump which is a rubber hose with a sharp loop that failed after a certain times. It leak and prevent proper fuel pressure to the engine....See links....
http://www.6speedonline.com/forums/9...fuel-pump.html
http://www.6speedonline.com/forums/9...ally-dove.html
http://www.6speedonline.com/forums/9...-pictures.html
If you can get access to a fuel pressure gauge, you can connect it to the fuel filter (engine compartment left side) and select ignition without starting the car and the gauge should indicate 3.8 bars or 55 pounds.
Fuel pump > one of the octopus fuel lines have cracked.
Intake leak, boost hose has undone, this includes a "F" tube split
MAF failure.
MAF failure.
My first gut reaction was something fuel related. I can hear the pump when I turn the ignition to on. Possibly a hose off, unlikely a split given all the hoses (f included) were changed out to silicon. No warning light on dash which generally equate into a MAF. I had a MAF go right after I bought the car back in 03 and the dash lite up like a christmas tree.
I recently had the seal around the fuel pump replaced as I was getting a check engine light. Guess its time to haul her into the shop. I forgot I had breakdown towing through my insurance so I guess a call will be in order to my shop to get her in.
Thanks for all the replies, and I will update once I get the repair started.
last note on bad fuel pump. it usually allows you to start the car. maybe even idle. but any pressure will usually stall the car. but again, based on what you're said, and what those here also sense fuel and pump related is the place to begin. fuel pump failures happen commonly, and much like you've described.
The above is exactly what is happening with my car. I looked and found the pump at Pelican for like $645. I use a shop called Abacus here in Norfolk Va and they are a race shop and fabricator. I have to believe they could fab up whats seems to be the weak link on the pump, the rubber hose at the top of the pump.
Just make sure the new hose is not in the way of the fuel float... ask me how I figured that one out...
I will remember to check, or have them check for the float clearance. What tools were necessary for getting into the fuel pump and replacing the hose? I wonder if this is something I can do here at home.
Anyone near Norfolk/Virginia Beach that would want to give it a go with me
I vote MAF sensor very typical of a car to run when above idle once down to idle stall. My only question is if the fuel pump is supplying fuel at upper rpms why would it be bad at idle? Usually fuel
pumps will not let the car run or not allow higher rpm. If you hear it before starting then stop, then pressure is built up.
Just a question on why a bad fuel pump will allow the car to run but stall at idle.
