Another satisfied UMW customer
I ordered the WG 1BAR kit, upgraded DV's and the X-50 flash from Kevin- got it all put together this evening and all I can say is wow. If you haven't flashed your car yet, give Kevin a call and buy yourself a Christmas present. You won't be disappointed.
Kevin has a kit to modify your current wastegates- they are 1 BAR springs and clamps- you have to grind open the housing of your wastegates, replace the spring, then use the clamps to re-close the housing. They net you about 300rpm lag reduction, and 30% earlier RPM TQ.
The Diverter valves were an upgraded Bosch set- my current ones didnt leak, as far as I knew, but I went ahead and replaced them anyway- Kevin had good enough prices that it was worth it to me "while I was in there".
