Bilstein PSS9's
Will ship... probably $70.
The shocks are at my installers right now but I can head over take picts if you need them.
Approx. 25K miles - no leaks - can be dyno'd here locally if needed.
Dyno testing will provide a print out of the compression and rebound of the shock at various settings and identify if all the shocks are within manufactured specs.
it's the best way to tell if a shock is up to spec and doing it's intended job.
---- I also found this explanation
Description
Force match your shocks for optimum performance. We will dyno test each of the shocks as received, then tune the adjusters so the forces match on all 4 shocks. This will provide you with a starting point for each shock and the knowledge that all shocks are performing the same!
In addition to force matching the shocks, we will run a full adjustment sweep of all adjusters on one shock. From this data you can determine what setting gives you what damping force. You will also know how much to change the settings for the desired change in damping. A report on shock condition and performance will be included with the data.
Description
