Tires for street/track suggestions.......
#31
I just ran the nittos all weekend and with adjustable thrust bushings you can dial out any "rubbing"... I did. The 245-40-18/315-30-18s worked well. Only key to remember is to start with COLD pressures as follows for our "HEAVY" 996TTs...
25# front and 24# rear cold. If the track is biased to right vs. left turns, start the left rear at one pound less than the others... You want 36-37# hot, no more... They get greasy beyond that.
Ran them all weekend and once I got them dialed in, they're GREAT!!! Very easy and predictable, and easy to slide and recover... I ran at over 125MPH in the uphill esses at VIR and could slide the car at will without issue with PSM turned off...
Mike
Mike
#33
Mike, great seeing you this weekend! We'll be chattin' more in the coming weeks I'm sure
I ran the NT01 this weekend as was impressed. I enjoyed running them on the GT3 and they didn't disappoint on the Turbo either. The grip is not anywhere near a Hoosier R6 but I am not going to smoke that crack pipe again ($$$) .....besdies, I don't have the setup to run that tire and it's going to stay that way!
I will change the front to the 235 next time out. I didn't like the small clearance I had. Just too close for my liking.
I was chasing my tail all frickin weekend on tire pressures and the halfway point through each session I was driving on greasy skates! Mike, I should have asked you about pressures as I just assumed I could start in the same range as the GT3. I had no idea I needed to be down around 24/25 to get them dialed in. Looks like I need to get back to the track soon to get this sorted out
#35
Doug....you're almost as bad as Lewis!
I know what happens when I place the order for R6's. It ends up costing me 15-20K in suspension, wheels, etc.
#36
I just ran the nittos all weekend and with adjustable thrust bushings you can dial out any "rubbing"... I did. The 245-40-18/315-30-18s worked well. Only key to remember is to start with COLD pressures as follows for out "HEAVY" 996TTs...
Mike
Mike
#38
Dell, It was good seeing you again as well man... You shoulda driven mine for a session... That woulda started you right back on the crack wagon...
Anything to help you spend your money, man!
About that exhaust...
Mike
Mike
#39
Larry, My Smartcamber gage showes about +7.2, but what I did was adjust them until they cleared the fender liners and lock them down there, and then re-set the toe. Toe was about 1/16 out total (1/32 each side) and worked well.
Mike
Mike
#41
I did it myself. You can heatcycle them by running them up to temps for about 10-15 minutes and then parking them. Then you're good to go... That was the advice the boys at Tirerack gave me.
Mike
Mike
#42
Just put AD08's on the car....on the street they are great. Good in rain too.
They have a decently thick tread, so early on they might be sub-optimal (for like 2k miles).
On turn in, superb....cannot say enough on the feel and stiff sidewalls. Comparisons for me are:
ps2, htr ZIII, conti contact 2, and pirelli OEM's.
I am 99% sure these will be my mid street/R tire for a while. I reviewed a lot of internet comments, but cannot say I have done a DE in them. Of note, I am now solo-ing...so my needs have changed too....
They are not too noisy for my tastes. Others have complained about them.
Jeff
Jeff
#44
I drove with them at 60-70MPH for 10-15 minutes.
Mike
Mike
