996 Turbo Forum 1999-2005
Tires for street/track suggestions.......
Old 04-11-2010, 09:38 AM
LVDell
LVDell's Avatar
Nitto Specs:
235/40/18 25.39"
245/40/18 25.55"
315/30/18 25.35"
Factory sizing is
Front 25.4"
Rear 25"
I will have to take another look at the manual to see what the requirements are on the AWD system but I can't imagine the 245/315 setup is going to affect it at all.
Old 04-11-2010, 09:58 AM
Liquidcooled
Liquidcooled's Avatar
Will the Nitto 245/315 setup work with the stock rims and offset without rubbing? I was going to get MPSC 235/295 but would like to try the Nitto setup if it fits without problems.
Old 04-11-2010, 10:18 AM
LVDell
LVDell's Avatar
I got rubbing at full lock with the Nitto when I ran it on the GT3. The only time I was at full lock was getting in and out of my spot in the paddock so it was a non issue for me.
Old 04-11-2010, 10:29 AM
Sanjeevan
Sanjeevan's Avatar
I am about to pull the trigger on NT-01 245/40-18 and the 315/30-18 for my 996 C4S. In stock suspension do you think these will cause any problems what so ever even at full lock with a C4S? I will be using these on streets as well, and would'nt want to make the turning circle much wider.
Old 04-11-2010, 10:59 AM
LVDell
LVDell's Avatar
There is no detrimental effect of it rubbing at full lock. It just rubs the fender liner a bit. If you don't like that then you will have a larger turning radius.
Old 04-11-2010, 11:13 AM
Sanjeevan
Sanjeevan's Avatar
Thanks, that is fine with me.
Old 04-12-2010, 01:47 PM
DesignerGenes
DesignerGenes's Avatar
I picked up a set of hollows and had them painted black to give the car an alterego when I'm feeling facetious and need to outfit them with rubber.
I have put a list together of tires I can run on street and the occasional DE.
Any thoughts on my list?
Additions/Suggestions?
LIST:
Nitto NT01
Toyo R888
Michelin PS2
Michelin Pilot Sport Cup
Yoko Advan AD08
Yoko Advan A048
I put a set of Kumho Ecsta SPTs on my Turbo S 8,000 miles ago (standard Porsche sizes). I intended to try them at a DE. I drove 30 miles to the track, put in a day on the tires, was impressed, and am still driving on them. I JUST replaced the rear tires (cord beginning to show), and should probably get another 8,000 miles from the front ones. Two rear sets for every one front set, just as expected
You've gotta put air in these tires to get them to perform; also, break 'em in hard. Starting with 32 front and 40 rear (summer), after 20 minutes on the track they're at 40 and 48, with no heat damage. I've had them to 150 mph, and to 110 in the rain. Traction is excellent, they don't roll over, and the damn things are cheap!
Old 04-13-2010, 12:31 AM
mooty
GT3 player par excellence
mooty's Avatar
Received 5,629 Likes on 2,314 Posts
Originally Posted by MechanicalEng
what about the Toyo R888s?? I dont mind to hijack this thread, just curious about your opinions
R888 vs MPSC vs NT-01
i echo dell's post on #14
Old 04-25-2010, 10:15 AM
joyride5
joyride5's Avatar
Look into the Kumho XS.
Old 04-25-2010, 11:17 AM
LVDell
LVDell's Avatar
I think I am going to go with the NT01's.
I got 40+ HC's with them on my GT3 driving pretty darn hard so these should fit the bill just nicely. I'll report back after the May DE.
Old 04-27-2010, 01:03 AM
jeffrh
5th Gear
jeffrh's Avatar
I have mpsc and have been very happy with them. About to buy a new set. Have tracked them and drive daily with them.
Old 05-02-2010, 09:18 PM
Sanjeevan
Sanjeevan's Avatar
I went with the Nitto NT-01. Used it this wknd. for the first time at M-O. In my C4S with stock suspension the 245 in the front and the 315 at the rear worked very well and no rubbing at full lock either. Is pretty decent in mild wetness too. For around $1k for a full set, highly recommended.
Old 05-02-2010, 11:59 PM
TT Gasman
TT Gasman's Avatar
I just tried RE11s on the track this weekend, they flat out suck.
Old 05-23-2010, 02:09 PM
TrackDays247.com
Former Vendor
TrackDays247.com's Avatar
NT01 1000%
Old 05-23-2010, 05:13 PM
Land Jet
Land Jet's Avatar
I need some new track tires and will be trying the NT-01's. My last set were Toyo 888's, noisy, otherwise I have no complaints. I have 37 HC on the front and think there are a few more left. Pretty good for a heavy car like mine.
What cold tire pressure do you recommend for the NT-01's? Hot temperature to shoot for?
Quick Reply: Tires for street/track suggestions.......
