Switched to the Mobil 5W-50 today
#256
Former Vendor
i am giving a shot to Lubro Moly 10w60 on my car. As a matter of fact, today i will do an oil change after closing. For customers, I use 0w40 strictly for obvious reasons, unless they bring their own oil.
#258
Running a 60W oil increases the chance of opening the bypass springs on a cool morning. I have seen this happen on this engine, the oil pressure gauge bounces at 5bar plus.. That means that on start up your oil is running on bypass. No filtration when the engine has the potential to have the most wear. I can see running the Castrol 10W60 in the desert AND if the ambient temps NEVER come down below 85F..
#261
Thank you, Kevin!
#262
Former Vendor
Plus, yep, I am in south TX, now it averages 50-60s and soon will run 100+ 6-7 months in a row.
#263
Isn't the 10w60 at 10w on a cold start?
#264
As the engine warms, the thickened oil overpressures the bypass spring pressure. The relief that occurs bypasses the oil filter. This engine is a dry sump, the oil is picked up/scavenged and placed in the oil tank, and then returned to be pressurized/pump thru the bearings and engine components.
Have you seen how the oil pressure behaves on cold start/engine warm up vs when the engine is hot.
When one looks in the manual we are given the 0W40 and 5W50. 10W60 is for extreme high heat geographic areas.. Like I said, 85 is the minimum. If you track the car and trailer it you could run it in the heat of the day. The vario cam modules, hydraulic solenoids, and inlet tappets DON'T do well with a 60 weight.
#266
Former Vendor
When one looks in the manual we are given the 0W40 and 5W50. 10W60 is for extreme high heat geographic areas.. Like I said, 85 is the minimum. If you track the car and trailer it you could run it in the heat of the day. The vario cam modules, hydraulic solenoids, and inlet tappets do well with a 60 weight.
Engine noise at idle is almost 50% off. Last night on the way back, car felt smoother.
I will report back.
PS: If you are in a Northern State, where your car is subject to extreme winter conditions, I would not recommend this oil.
#268
if my rams ever fail again i will have them repaired asap as i like things to work as they were designed, and have always taken great pleasure in viewing them being deployed at speed and being retracted in my rear view while slowing. there is something reassuring about seeing that, though i also never believed that i am somehow more "stable" for them working or not lol
but 150+? sure.
but 150+? sure.
#269
For years ran Motul 300v 20w60 and had no issues in a Fl climate. However the engine rattle was present after warmup. After all the discussion on Rotella t6, it was time to try the comparison. So far the T6 runs much quieter so far. Imagine that; T6 quieter than 20w60.
So I tried it in my Jeep and now I get lifter noise on cold startup, so I'll switch back to Castrol on the Jeep.
#270
Absolutely NOT
the first numbers of the oil is a relative number to help you gauge how much the oil thickens when it cools
you always choose the weight first
then you choose which XXW- you need for your purposes
do you live in sub zero temps and your oil sump is also at sub zero temps every cold start?
or
do you live in summer climates year round and you sump temps are 20-30C every cold start?
e.g.
0w40 thickens much less upon cooling compared to 10w40
they both have the same viscosity at 100C but at 0C the 0w40 will be relatively much thinner than the 10w40
but 10W40 & 10W60 ARE NOT at the same viscosity upon cooling
if they're not the same viscosity at 100C why would they be the same viscosity at 0C?
anything labelled 40 weight is 40 weight from -273C up to its Flashpoint
anything labelled 60 weight is 60 weight from -273C up to its Flashpoint
so
at 100C
0W40 = ~14cst
10w40 = ~14cst
10w60 = ~23cst
at 40C
0w40 = ~ 79cst
10w40 = ~ 95cst
10w60 = ~ 160cst
or
e.g.
so
at 100C
0W40 = ~14cst
10w40 = ~14cst
10w60 = ~23cst
at 40C
0w40 = ~ 79cst
10w40 = ~ 95cst
10w60 = ~ 160cst
