Switched to the Mobil 5W-50 today
#211
#212
Simon has a point.. All oils will sheer to a lower weight. The vaned pumps and chains are really tough on oils. The 30 weight turns to a lower weight as you put the miles on.
#213
#214
The way I see it:
Manufacturing recommendation is the best compromise.
For hotter climate 5/50 is best compromise as far as us users are concerned.
Track duty, hot climate, really pushing at max performance, 10/60.
Brands? I think all top brands are equally good. Frequent changes will do more than top brand choice.
Just my 2 cents.
#216
#217
I am going to purchase Mobil 1 5w-50, drain plugs and oil filter. Summer is approaching and it does get quite hot here in Melbourne.
Can you tell me how much oil is needed on refill.
Is it really necessary to empty oil from the Turbo's as I read that you can easily strip the threads.
James
#219
I don't know how your oil is packaged.. You will need 7.5 to 7.8 quarts. If you let the oil drain over night you could need 9 quarts (the hydraulics will shed oil and migrate out of the engine)..
If you don't want to remove the turbo drain plugs, don't.. If they haven't been removed, you might not be able to remove them..
I like to pour in 5 or 6 quarts and then turn the engine over (remove the fuel pump fuse).. Watch the oil pressure building and then pour in a total of 7.5 quarts.. Turn the engine over and build oil pressure >> put the fuse in and then start. This is just a optional method.. Use as one wishes.
#220
I like to pour in 5 or 6 quarts and then turn the engine over (remove the fuel pump fuse).. Watch the oil pressure building and then pour in a total of 7.5 quarts.. Turn the engine over and build oil pressure >> put the fuse in and then start. This is just a optional method.. Use as your one wishes.
I will follow your advice.
#221
I have read on a previous oil change thread that the oil tank drain plug needs to be removed "OPPOSITE to the removal of the drain plug" does this mean clockwise direction to remove ?
Or do you turn anti clock wise to remove all of them as you would normally to all bolts and nuts ?
"2. Remove the oil tank drain plug. This requires the 27mm wrench and 19mm socket. Use the 27mm wrench to apply force OPPOSITE to the removal of the drain plug"
this is the thread
https://rennlist.com/forums/996-turb...-diy-pics.html
this is the thread
#222
the 'support'-nut welded on the tank needs to be held stable, do not try to turn it but only use a wrench to provide negative force against the torque required to remove the drain plug....for the tank, a good way(if plug isn't 'seized'/over tightened) to ensure equal forces is to use your hand to squeeze the wrenchs together rather than 2 separate arm movements...hope that makes sense!
drainplugs for crankcase, tank, etc. are all conventional thread, counter-clockwise to remove
#223
I will be doing it tomorrow.
#224
Well I'm half way there, this is where l'm at so far.
- warmed up engine
- removed fuel pump fuse
- cranked it over and burnt remainder of fuel
- removed oil filter with non genuine tool which was a bit tricky but got it off
- removed both oil plugs
- leaving over night for remainder of oil to drip out as Kevin suggested
- Don't have a torque wrench so I am going to try without, just maybe tighten reasonably firm.
- In the morning placing new washes, filter and in M1 5w-50.
- Crank it over without fuse to get the oil pressure up and then I'm done.
This is my first personal oil change on a Porsche and find it quite satisfying that l know it will be done properly.
Couldn't have done it properly without everyone's help from this great forum , so thanks heaps... really appreciated.
- warmed up engine
#225
Don't have a torque wrench so I tightened filter casing as hard as I could by hand and then turned it a further 1/4 to 1/3 with tool, hope this is OK.
Can some one tell me if this is not advisable.
