is this residue OK on oil cap?
#32
You should ask T2
#33
It is basically an emulsion of oil and water ( like you would see after shaking a bottle of oil and water (or vinegar). Actually water and oil do mix.. just not very well. It is probably the detergents in the oil that keep the two emulsified.
Driving for longer periods will drive off the vapor but oil vapor and water vapor will reach the filler tube cap and condense there. Very likely that area does not get as hot ( the reason they can make it out of plastic) and so, if one does not drive for extended periods or the ambient temperature is lower, it will be more challenging to drive off the water vapor at the top of the tube/in the cap.......harmless
#34
Lewis: 5555 miles? What are you waiting for? Barrett-Jackson? You don't want to see the odometer click off of 5555? I guess that's the downside of being a Super Moderator. No time to drive.
#35
The car has been at the detailer's (ranked #9 in the USA in Autoweek a while back IIRC) since December. Hoping to pick it up this week and bring it home (probably in the trailer since the roads are still sand/salt)
I just like the car and have had a lot of things keep me from driving it past few years.
#36
Just checked mine and it has the same mustard on it... I have been washing it often and it is cold here... I usually take the long way to work to be sure the engine gets hot, but the drive is around 15 minutes one way...
Not sure what kind of oil is in it - dealer changed it before I bought it. I will be doing an oil change this spring. Torn between Mobil 1 and AMSOIL...
http://www.turboflatsix.com/oil-reco...ghlight=diesel
#37
Thanks dtmarsh. Are you stalking me on rennlist now? :lol:
I am going to do an oil change soon. I have much reading to do and have already done a ton. From what I have read, everyone seems to come back to the original fill...
#38
You're welcome. Yea, it's a real learning curve, but such a rewarding one.
#43
Sorry to chime in so late. Thinking about this one - could it be that the engine gets plenty warm during your driving then while it cools down the oil fill cap (which may have a slightly compromised gasket/seal) is allowing colder air in and condensing on the cap causing the yellow oily mess on the cap and thus an oil cap replacement will fix this issue?? Just a thought. T2
