is this residue OK on oil cap?
adding some oil the other day, I noticed the residue pictured inside the oil cap. Is this normal? looks and feels like Mustard, yellowish and gooey...
TIA,
Sam
TIA,
Sam
It's important to run the engine long enough to cook off the moisture, which is a by-product of the combustion process. It the water is condensing on your oilcap, there's a good chance it will be condensing on other, more expensive parts (camshafts, crank, etc) when they cool down.
Well, I usually take a 25 minute x2, %80 hwy 4 days a week (avg. speed 65+ mph) and regular driving the other 3. The car was garaged 2 weeks (long time) due to blown rear tire. Condensation from what?
Condensation from cold damp weather... Plus the engine produces water as a by-product of combustion. What kind of oil is in it? My brother used to use some kind of oil and his car did the same thing a long time ago...
My TT does not condense moisture on the cap like that, but I do get that on the '79 930. I take the cap off when I get home and let the vapor evaporate out of the oil tank, it seems to have addressed the issue.
my daily routine is to warm up the car for couple of minutes (2-3) first thing in the morning then at least let it cool down for a minute or two before turning it off...I cleaned the cap and will monitor it closely for next few weeks, almost time for an oil change...
I don't get that on my cap. I cool down for 2 minutes every time and usually wait for the RPM to drop after I turn it on (usually 10-60 seconds..), to move out.
I use the car as a DD though.....
If that were my car, I'd be at the best shop I know getting some help. It just looks very bad/wrong/expensive. I don't know what is wrong, but I'd find a guru that did. I wonder what Statman was thinking....
JB
JB
Are you serious about taking the cap off to let the moisture out?
