3 MAF's in 6 months HELP!!!!!
Yet again I've got the same old PSM & ABS Failure lights coming up Error code is 115 Hot air film MAF - durametric , what could be causing this really annoying recurring problem? I have the Evo V Flow intake and a pair of Forge recirc divertor valves along with a FVD flash. This is the third time I've had this problem, just looking for ideas as it's getting old having to buy a new MAF sensor every month.
Some would say search...but, I'll just blurt it out. Your EVO CAI is likely the issue. They have a fix (a sock gadget).....but many on this forum and on 6speedonline.com have dumped these units for stock, UMW, or Vivid.... Some people don't get MAF issues with the EVO unit, mind you. Clearly your particular car and unit are likely non-compatible.
It could be a lot of other things (oil off the filter, etc., but many threads have been like this one).
Good luck.
JB
Good luck.
JB
reply
Could it be something not quite right with the programming? Was the programming adjusted to compensate for the increased air flow? Maybe some of the experienced tuners can suggest a fix. Just a thought.
I am running the Vivid this weekend at Daytona let you know if I have the same problems..hope not. their design seems improved (at least I think Oak, but it is yellow!!)
MAF Problem
Yeh, I will put the entire intake system back to standard, just a bit pissed off that this crap Evo intake has cost me around 1000 bucks to buy and a further 1000 in new MAFs all for nothing, also I cant see the difference with the Evo and the vivid it's still a intake box with a cone filter attached to the MAF housing. About to order new MAF NUMBER 4! FANTASTIC!!!!!!. Thanks for the input guys.
I was going to buy one from another Rennlister, but in doing some research I ran across threads like this one and it didn't seem sensible to invoked the gremlin gods for no really good reason. The OEM on works just fine....i hit 1 bar routinely...and periodically even 1.1 while using the OEM filter....and it didnt' cost me anything except the price of the car. Sometimes the old addage ....If it works dont' fix it ....makes sense.
Like I said seemed safe enough to try again, believe me if it sucks or is great you guys will hear about it. Daytona in 4 days!!!! Will run this intake hard for 3 days at Daytona. Then 2 days at Sebring in 2 weeks, that should be a good shake down!!
From what I "understand" and that may be limited, the Vivid box is different in that they added a screen before the MAF like the factories to keep laminar flow better, and the EVO box does not.
The thing I liked about Vivid was they would replace your MAF for free if you blew it due to their box (not sure how you prove it!)
