Over-Rev Documentation
I need some advice right away: I just placed a deposit on an '03 X50 at a Porsche dealer. (More details to follow once I close on the car later this week.) I asked the dealer whether there were any over-revs on the car and he told me that the car could not have had any since the dealer would not be selling it as certified if it had any over-revs. I asked him to ask his service department to print out the report showing the Type I and II over-revs, which he agreed to do. What is the exact name of the report or documentation that I should be getting back to nail down this issue? Is it a big deal for the dealer to generate that report? (I did not see it as part of the certification checklist I reviewed.) What part of the engine actually records this information? Can it ever be erased or altered by the dealer to hide the over-revs? Thanks.
I'm not sure about a report, but you can have them hook up their PIWIS or PST2 and just go to the ECU information screen. It will show Type I and Type II over revs...like the screen below. It is stored in the ECU and can not be erased or altered (I'm sure some could hack it, but not just anybody). Oh the screen shot is from durametric, but it will be similar (and yours will be Motronic 7.8)
Technical Guru
I have a few Questions regarding this Over Rev Issue..
1) How does an Over Rev 1 Differ to an Over Rev 2??
2) How can our cars Over Rev if they have a Rev Limiter??
3) Does the Over Rev count if it is a split second or does it need to be Over Reved for a period of time??
Answered many times:
I: Bounce off the rev limiter- happens to everybody, can't be avoided if you use first gear very hard
II: Missed downshift- eg. when trying to shift from 5th to 4th, you catch second, and force the engine to rev to a very high number
Counts each ignition cycle instantly. AS
Thanks AS
The dealer's DME vehicle data report states in part as follows:
Number of ignitions, range 1
340 346.0 h
Number of ignitions, range 2
Operating hours counter
347.8
Can anyone tell me exactly what this means?
Also, the report shows "Total distance" of 014328km, which equals 8903 miles, which is 309 miles less than on the odometer. Why would there be a discrepancy?
Thanks.
340 346.0 h
347.8
Thanks.
rfl;
You have 347.8 hours of operation on your engine.
You have Zero Type two over-revs which is telling you that there is "NO" forced mechanical mis-shifts to hurt your valve train. Which is VERY good.
You have a low type 1 over-Rev which is time spent at Redline or shifting at redline with Rev limiter engaged.
The last time that someone shifted and hit the REV limiter is roughly around 1.8 hours ago.
Don't worry about these low counts for type 1's..
I think it is very misleading to equate type 2 overrevs with missed shifts. Certainly a missed shift can cause type 2s, but I have proven that you can generate type 2s by hitting the rev limiter before an upshift.
Jeff
Technical Guru
