996 Turbo Forum 1999-2005
NO oil Pressure
Old 08-18-2007, 11:10 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,325 Likes on 1,299 Posts
Default NO oil Pressure
My friend has a 2001 TT and it was parked outside for a heavy rain/downpour, anyway when the engine is started the oil pressue gauge goes to about 1/2 bar then back to zero also the red warning light comes on and stays on it says lo oil pressure , we have only started the car a few times for not more than 20 seconds it doesnt sound like any knocking however the owner says that he thinks it noisier, than before however he also says that the light is making him think that , previous the car ran beautifully and was only moved outside for garage work.............any thoughts. is it possible that a connector could have gotten wet and be causing this problem, next step is the flatbed to the dealer
Old 08-18-2007, 11:22 PM
Kevin
Kevin's Avatar
Most likely the oil pressure sensor or connector which is located on the oil filter console..
Old 08-21-2007, 08:37 PM
99firehawk
99firehawk's Avatar
let it run for a few minutes see what happens
Old 08-21-2007, 09:59 PM
John D II
Basic Sponsor
John D II's Avatar
Mine began working intermittently last fall - all the warning lights, etc.. It was the sensor as Kevin mentioned...I am told it's a common problem. Very concerning when it happens, but mine kept popping back up quickly and stayed high, then would drop for a few seconds and run correct again for a while. It was kind of easy to tell the gauge was getting an intermittent signal.
991.2 GT3 RS Weissach Racing Yellow
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
former 1972 911T white, 1984 911 3.2 Targa black, 993 cab white, 993TT arena red, 993TT silver, 996TT speed yellow, 991.1 GT3 white
www.speedtechexhausts.com
info@speedtechexhausts.com
Testimonials SpeedTech Exhaust Videos facebook
Old 08-25-2007, 07:06 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Here we spent some time removing the Check valve on the bottom of the oil tank, per TBO 1728, anyway when it was removed the valve was found to be frozen in the closed position so as to cut off the flow of oil and thus no oil could flow to the oil pump , a new part is on order the old check valve did not have the blue paint dot that the TBO called out, updated will follow, the part should be in next week, also we will be changing the oil and filter
Old 08-25-2007, 07:14 PM
Kevin
Kevin's Avatar
That's not good.. I'd be standing right there when the oil filter comes out.. Spend some time sifting thru the pleats of the filter.
Old 08-27-2007, 02:51 AM
ebaker
ebaker's Avatar
I'd run an oil analysis.
Quick Reply: NO oil Pressure
