Kevin Upgrade K16s to K24s
Rennlist Lifetime Member
Turbos will cost you around 3K or so. Install is about a 6 hour deal. It is not hard, just time consuming. I also suggest doing plugs while you are in there if nothing else to head off a large labor bill in the future.
With proper software it IS well worth the upgrade. Your K16 software will not work with the K24s.
Richard wants to purchase my turbochargers and run them with his Upsolute programming.. It's not going to happen.. Been there done that..
Also do u upgrade stcok K16/K16? how much? hp/tq gain?
That price was for my Stage 2 tuning system, the package is supplied with turbochargers and programming. It also includes my billet wastegates installed, 5bar fuel pressure regulator and Race gas file.
For programming one gets to keep your stock Porsche file, pump gas performance file, Valet file and race gas file.
Headers, Zero Clearance mods, bypass valves and clutch kits are options.
Search for KPG's post on the Stage 2 setup, 'Dyno Numbers Are In : A Lesson In Power Under The Curve' and it says it all. This is a great package and 0 clearence really gets rid of any material turbo lag.
