Spark plug choices
This is what I've gotten so far. I haven't been able to find the Bosch Fr6 LDC or the Denso PK20PR-P as an applicable plug for a 996 Turbo. Am I missing something?
http://www.sparkplugs.com/results_ap...1&AAIA=1388336
Kevin told me the Bosch FR6-LDC. So I put them in. Beru's came out. Car sings now....wasn't bad before (26k)....but it seems better. I think if plugs work, one is just "happy" when they don't work.....
and I have been told that cold weather, etc., can play make less than ideal plugs an issue. So, I listen to the guru and will likely just not have a problem.
FWIW.
JB
FWIW.
JB
Kevin, is there any benefit to indexing these dual-tip FR6-LDC's? By that I mean line up the electrodes in any particular way, parallel to the crank or perpendicular, or?
Ted K
Ted K
It will be tough due to the two torque values specified. We also have a 4 valve head. The benifits might exist, but not the extent when you had a large 2 valve head.
Boulder with the crap 91 octane the Beru's are spent in less than two years. Faster when you are running higher boost.
