Dyno Numbers Are In : A Lesson In Power Under The Curve
Originally Posted by TB993tt
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Great curve, I think that is what is more important than the peak numbers themselves, after all, everything is relative in life, chassis dyno vs chassis dyno run, they are all comparable.
Great value for money, you should be very happy with it, even with the, most likely, real 750 NM torque that you might have
Thanks for posting so much info about your setup, an example to follow.
Originally Posted by Jean
Yes TB, remind everyone that I am the bad guy
Great value for money, you should be very happy with it, even with the, most likely, real 750 NM torque that you might have![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
![offtopic](https://rennlist.com/forums/graemlins/offtopic.gif)
1 Maybe our dynos are correct and your cars just aint that strong- this is America, we can Supersize at will. 2: It would be cheaper just to ship your car over here, dyno it, and go home with an extra 200HP- rather than spending all that money upgrading your air coolers
Originally Posted by Dock
For comparison, the only EVO stage 4 dyno I have shows your program and the EVO program are close in average torque...yours having better low end average and the EVO having better high end average. Just looking at markers each 500 rpm starting at 2500-6500, the two dynos show the average is within about 8 lb-ft of each other.
Kevin, Congrats...
Nice numbers.. BTW you should have your Pocket loader with the Drag file loaded by 10:30 tomorrow.. Start fueling your tank with 100 octane..
Can you mount a video camera for a few runs??
Originally Posted by Kevin
Kevin, Congrats...
Originally Posted by 9Eleven
Awesome numbers Kevin. I am not suprised.
Originally Posted by KPG
Dock, since you are in the GIAC family... you would be well served upgrading to a Stg4 when and if you choose to upgrade.Kevin
One of the biggest things I get out of your dyno numbers is that Kevin builds the best turbos in the world.
This is still an entry level kit from Ultimate's product list, albeit one that has been tweaked and massaged extensively.
Dock, the programming is not Sportec.. However, I have had "help" (which I am am forever grateful of your help!!!) ... This program has been perfected to the state that we see today.. This latest version is running my billet wastegate kit. If you couple the wastegate kit with the Zero Clearance turbocharger option, we see the ton of torque under the curve. The heart of this kit is having all the components blending together. And with the basic Stage 2 kit costing only $5,895.00 (turbochargers and programming) that's alot of bang for the buck.. With Kevin receiving his drag file tomorrow, we should have a 2nd chapter..
How was the 3750 pound weight of your car calculated?
