996 Turbo Forum 1999-2005
Stage X X X X --Thats 4 X's
Old 04-02-2003 | 03:01 PM
  #181
BC's Avatar
BC
Post
The reason for the four injectors, or "nozzles" -
Is this because of the hp level?
Old 04-03-2003 | 02:08 PM
  #182
BC's Avatar
BC
Post
I love clean new parts.
Old 04-03-2003 | 02:20 PM
  #183
HBdirtbag's Avatar
HBdirtbag
Post
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by BrendanCampion:
<strong>I love clean new parts.</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">and clean welds
Old 04-03-2003 | 02:31 PM
  #184
HBdirtbag's Avatar
HBdirtbag
Post
did you get the new fuel cell in yet?
Old 04-04-2003 | 12:23 AM
  #185
Bob M's Avatar
Bob M
Post
Chad,
The pictures of the wheels and tires look good, but I bet they are even better looking in person! I am curious ... How would you describe the ride and handling characteristics produced by your new wheel/tire set-up as compared to stock? Is rolling the fenders a process that can be easily screwed up? Do you think that most good body shops could perform this operation, or is it something that takes more of an "artisan" touch to do correctly? Any idea on what a shop would typically charge to do this? Thanks for keeping us all in the loop on your project! You should write a book when it is all finished.
Bob
Old 04-04-2003 | 01:06 AM
  #186
HBdirtbag's Avatar
HBdirtbag
Post
wow, heated and molded. i woulda just cut it
These are the little things alot of tuners don't do. Props to S Car Go for not forgetting the little things.
Old 04-04-2003 | 01:09 AM
  #187
HBdirtbag's Avatar
HBdirtbag
Post
yea, pictures of the rolled fenders would be awesome.
Old 04-04-2003 | 04:19 AM
  #188
Zippy's Avatar
Zippy
Post
<a href="http://www.carrollsupercharging.com/" target="_blank">http://www.carrollsupercharging.com/</a>
Carroll Supercharging also make a water injection system. <a href="http://www.carrollsupercharging.com/" target="_blank">http://www.carrollsupercharging.com/</a> I installed a 2 phase system on my 1999 7.4L Suburan. It kicks into low pressure at 5 lbs boost and shifts to full pressure at 7 lbs boost. These pressure points are adjustable. I am pushing 12 lbs boost using a sigle 10 gallon per hour nozzel. I am going to wait until it heats up (summer) and if there is no sign of detination, will put in a smaller nozzel. I hope to get the truck on a dyno this spring and hope to see 500HP and a signigicantly higher torque number. They also have a system using 2 nozzels (and 2 pumps?). I am using a 60% water / 40% methanol blend. I have been very pleased with the product. <img border="0" alt="[cherrsagai]" title="" src="graemlins/drink.gif" />
Old 04-04-2003 | 01:27 PM
  #189
GreggT's Avatar
GreggT
Post
Curious on the FM-10s......I see 12mm spacers used in back?....was there a reason 10s with 12mm less offset weren't used (for a bit more rim, etc).
Old 04-05-2003 | 12:47 AM
  #190
GreggT's Avatar
GreggT
Post
Yep....I understand, right now I've got wheels and spacers all over the place here (changing to summer fitments) and if a guy had all the time in the world he might think he could calculate offsets & anticipate perfectly.......truth is, you can spend $7K and still, at the end of the day, you're not 100% sure til you slip em on for the 1st time (I have another of those 'gambles' going right now).
Course, if you could really believe tire manufacturer's dimensions...life would be a bit easier
BTW...last set of custom offset rims from HRE, got to me in something like 4 weeks (not too bad I thought)....Fikse was just a tad longer, but right in there.
Old 04-08-2003 | 03:12 AM
  #191
Deanger's Avatar
Deanger
Post
Hey CJV
I think it is time to continue this on a new thread, this one is getting huge. Those custom 'pipes' sound awesome!
Congrats!
