DIY Header Mod for you 996TT owners..
#31
The German tuners that I have talked to have said 750-800HP.. Your going to have to pull your engine apart at that level.. Do a port job on your intake runners and cylinder head and then jump up to some bigger headers..
#33
Zippy,
You need a die grinder unless you get the industrial strength dremel
Kevin,
The headers are off to Jet Hot and I'll send pictures as soon as I get my camera back from my folks. Thanks again for all your GREAT advice!! I owe you a couple of
Kevin,
#37
Hey Kevin can you reload the pictures of the grinder and porting bit as my computer did not bring this up--just a red X. Also can I buy the bit from you directly or can you tell me where to buy that and also the polishing bit, thanks Mike
#39
Mike, here is a picture of the hardware that I use and recommend..
The mandral can vary in length. I use a 1/4" shank.
The sanding and polishing rolls range from 60 grit to 150 grit..
I do have these items in stock.
![](http://forums.rennlist.com/upload/p1010287.jpg)
#40
Would this help on a 02 x50 tip ??? The only thing that I do not care for is the turbo lag from 1500 to 2500 rpm. Is there any other way to inprove turbo spooling ? I do not care about max hp just turbo spooling!
#41
kevins proted headers, zc turbos, and programing will change all that for you.
www.ultimatemotorwerks.com
#42
I had Kevins headers with his stage 5 ZC turbos... and I simply flew ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
BTW- Just like Kevin said- you really do not need expensive headers for 600 hp cars... I Guess Craig saw it first hand... and hes well over 600 hp. Just a note: Scott( divirexxtreme) has a protomotive 600 rwhp car running mid 10s at the track and he is on stock headers( not even ported). Todd K stated that one does not need them at that level. he trapped 135 mph in a 1/4 mile... not bad.
#43
BTW- Just like Kevin said- you really do not need expensive headers for 600 hp cars... I Guess Craig saw it first hand... and hes well over 600 hp. Just a note: Scott( divirexxtreme) has a protomotive 600 rwhp car running mid 10s at the track and he is on stock headers( not even ported). Todd K stated that one does not need them at that level. he trapped 135 mph in a 1/4 mile... not bad...things that make you go .. hmmmmm
