Afraid to Start My Car - Loud Start Up
When I start the car after 3+ days, it sounds the same as a PS pump (or any fluid pump) running dry. It's loud for 1-4 seconds and then quiets down. Consistent with a pump starting dry. I've topped off oil, coolant and PS fluid (needed 0.5 liter!), but still get this noise on start up. I had this happen on another car, ignored it, and ended up paying $2,500 for a new steering system (pump, rack, every hose and reservoir).
I rationalized this for a while but can't anymore without some reassurance or a way to fix it, so here we are (and thank you for helping).
I drive my car about twice a week. It gets opened up now and again but no racing and nothing all that jerky. I'm a wimp on the clutch, and at this rate, I'll bring it with me to use on my next car
I'm in Austin where the temperatures are over 100 in the summer so I don't drive as much unless it's early or rained the day before.
Do all these cars start loud? I'm out of fluids to check (oil, PS Fluid and Coolant...am I forgetting anything?) but this is also my first dry sump car, so maybe it's oil circulating but my guesses are unproductive at this point.
Can you post an audio clip of the sound? Is this different than the normal Mezger timing chain rattle?
The timing chain goes dry if you let it sit for more than a day in hot weather and it will rattle until it gets oil on it again.
Sounds normal to me.
Mind posting a video or sound clip of it?
Thanks everyone for the heads up. Been working all day but I started it up and of course it didn't make the sound but for a second....but here it is.
Three was a recall on steering pumps back these car were new but that was due to a tea kettle type sounds.
At start, look at the oil pressure gauge if the noise stop as soon the pressure rise, welcome to the club! I live with this "growling on start" since I bought the car in 2008.... It happen only after a couple of days sitting in the garage.... I also tried all kind of oil and viscosity and could not stop it from happening.... Good luck....
See post#34: https://rennlist.com/forums/996-turb...tart-up-3.html
This is really helpful. I'll keep an eye on the oil pressure gauge. It's usually at 2 during idle and goes to 4-5 under throttle.
Still going to keep an eye on everything but no longer afraid to start it up. Thanks everyone.
