Gearbox pop !!!
#31
You were actually only 2k past the factory recommendation, which indeed seems woefully inadequate. I do mine every other oil change.
#32
What fluid do you use? Am thinking as the car isn't being driven at the moment, I may change it too.
#35
did you say you change GEAR oil every other oil change?! if so, that's what i would call very labor intensive and highly pro-active!
2fknfast. delvac 1 75/90 with no slip additives ( important ) since im using the wavetrac. prior to the LSD i ran redline.
#36
looks like used gear oil to me.
#38
Nasty would be metallic gear oil...
Thats just used gear oil.
if any oil has a sheen akin to metallic paint in the light, youre looking at future problems.
#39
When I swap the oils out of the Fords, it is the same color as it went in.
#40
~5k
That was directed at the thread starter, but you had pointed out the 90k factory service interval.
I use the same thing.
Prior to my transmission rebuild, I didn't want it to get any worse (and I wanted to check on the drain plug). After, I want to make sure I'm taking care of my 5-figure box.
not sure if that reply was directed to me? i never go over the factory rec, in fact i cut it below half changing mine every 40k miles or so.
k9turbo (06-23-2020)
#41
amen to that.
#43
