996 Turbo Forum 1999-2005
Gearbox pop !!!
Old 06-20-2020, 07:08 AM
hmch996t
hmch996t's Avatar
Default Gearbox pop !!!
Latest issue
I have a temperamental 1st gear on my car at certain times it decides to pop back into neutral.
After research I have found the common issue with the clutch slave cylinder.
When i was inspecting the slave cylinder there was zero oil around the cylinder ?
However when I was inspecting the cylinder I did notice an oil leak from the box itself it looks like one of the gear select arms ?
Here's the video i made :
https://youtu.be/HZvpiTZtOBM
Any help appreciated
Old 06-20-2020, 12:35 PM
enzowho
enzowho's Avatar
When I first bought the car I’d sometimes not fully engaged in 1st. Felt like it was seated but would pop out as soon as the clutch made contact. Was just operator error on my part (and a bit of blame on Porsche for the shifter feel).
Beyond that, this could be shifter/cable issues needing some work or worn parts in your gear box. The shift arm leak seems somewhat common and can only be replaced by opening up the gearbox.
Old 06-20-2020, 01:30 PM
CTS
CTS's Avatar
Check the output shaft for the front drive for end play. If there is perceptible movement then the pinion bearing has failed and the trans will need a rebuild.
This is the only reason for popping out of 1st gear that I have seen.
Old 06-20-2020, 03:42 PM
k9turbo
k9turbo's Avatar
could also be rounding of the dogring of the 1st gear triple cone synchro. that's what happens to 1&2 synchros to allow 2nd gear pop. if it is a bad 1st gear synchro then that also is a labor intensive fix.
if you are "lucky" it will only be a linkage issue. i doubt it has anything to do with the slave but that YT clip the parts looked loose as a goose. so, maybe.
Old 06-20-2020, 06:04 PM
hmch996t
hmch996t's Avatar
Here's my power steering fluid level ( picture attachment )
Could this confirm that the slave cylinder is busted ??
Due to the lack of fluid ?
I do have a fluid leak behind front right hand side wheel.
Old 06-20-2020, 11:05 PM
k9turbo
k9turbo's Avatar
that ain't right. if the slave master ( is this language still legal? ) cyl is leaking check the reservoir for fluid and it can also migrate into the cabin under the steering column. it's drivers side. can't imagine what could be leaking on the right side unless it was a radiator? but of course that's not pentosin
i've never seen pentosin that low on the stick before.
Old 06-21-2020, 08:42 PM
2fcknfst
2fcknfst's Avatar
Received 4,040 Likes on 3,071 Posts
Or that color - looks a wee bit dark.
I think you can use that language if you are referring to yourself...
Old 06-21-2020, 10:58 PM
k9turbo
k9turbo's Avatar
not touching that lol
Old 06-22-2020, 02:03 PM
hmch996t
hmch996t's Avatar
I decided to check my gearbox oil I thought that would be a good way to eliminate other issues (should of started there)
Bad news I'm afraid there are fragments of metal in the oil.
The sump plugs is covered with metal
Is this a definitive gearbox rebuild job ??
Old 06-22-2020, 02:14 PM
manimal
manimal's Avatar
Hate to be the bearer of bad news, but my drain fill plug looked similar when I was having intermittent issues going into first gear.
I ended up having to rebuild the box. On the bright side, it was worth every penny, as spendy as it was.
Old 06-22-2020, 02:29 PM
hmch996t
hmch996t's Avatar
How much did it cost you to repair ?
I'm only having issues with 1st gear
Old 06-22-2020, 02:35 PM
Dock
Dock's Avatar
How many miles are on you car?
Old 06-22-2020, 02:37 PM
hmch996t
hmch996t's Avatar
It has 92k miles
Old 06-22-2020, 02:46 PM
k9turbo
k9turbo's Avatar
It has 92k miles
time for bearings and at least the 1/2 synchros. i replaced my bearings and had a wavetrac installed for 4k.
but i've seen people pay as much as 8k to get that done.
Old 06-22-2020, 03:14 PM
2fcknfst
2fcknfst's Avatar
I would do all of them - if you're in there, might as well do it right so you don't have to pull it again later.
Quick Reply: Gearbox pop !!!
