So this happened...
In a completely random manner, I started the turbo this AM and immediately got a p300, p306, p309 code (random misfire, #1 and #3 misfire) as the car was warming up.
I reset the codes, restated the car and no issue as it warmed up. Recently, I swapped out all the coils and put in one step cooler plugs to accommodate the Cobb tune.
Sometime ago, I was informed that my throttle body was most likely bunged up with crud and this is most likely the reason I was seeing a little hesitation with throttle application; although not yet installed, I have a new TB and an IPD plenum. Occasionally, I am getting one, or both banks (cats) inefficient code. I attribute that to the TPS being in a different position than the butterfly on the TB, and/or the TB not being open enough to provide the required airflow to the amount of fuel in the engine, making it run rich.
My question is - are the two problems related, or should I be looking at something else?
Once the car is warm, these issues seem to disappear, however I am not yet fully up to speed on how all the parts are programmed to run together; in the old days, I'd pull the plugs, clean them, re-gap them, check the wires for cracks and look at the distributor for wear... Times have changed.
Cheers,
Cheers,
I do. I also have the Speedtech 3.0"(ceramic coated), 100dpi cats - I can see soot on the tailpipes, and I cannot really wring it out in the city, so most of my driving is low load.
Were you doing something similar, or just resetting every time it threw a code?
The normal inefficient cat code throws during cruse on the freeway, not typically at start up. At least for me. I would get it a bout once a month or so and just reset it. then i had my tunner code it out as part of a "Msport tune"
So did I, with the 200 cell cats that shipped with my Kline back in 2015. i recently installed Kline's newer HJS 200cell cats and lo and behold, no more cat inefficiency error messages!
So, is there a fundamental difference between 100 and 200 cell cats other than flow?
I actually have had the same problem at cruise 60/70mph; that was the first time when I thought the differential timing between the throttle opening and fuel being delivered was in fact out of sync, ie, it would run momentarily rich prior to air being available to burn.
I have never gotten the cat codes, so they are not necessarily related.
Btw, I never have gotten the cat codes. So they are not necessarily related
Cheers,
Cheers,
If I let the car from a cold start idle, i get misfires. I can monitor them with the durametric. Sometimes enough to trigger a codes P300, p303 and P306 (random misfires, cylinder 3 and 6). I can see some misfires on other too, but never enough to trigger a code. Once the car runs for a minute or so, and the choke comes off, all misfiring is over. Its like an on off switch. If i start the car with the MAF unplugged, it never misfires. I changed plugs and coils, no change. I changed the MAF, no change. I boost tested the intake, tight. I smoke tested the low pressure side, no leaks. I'm currently at a loss. So let me know if you find it. Mine is a stock X50 with 50k miles.
Forgot to note, I have never seen the cat code, or other codes. So they are not necessarily related.
Btw Macster had it too, I do not know if it was ever resolved (post 8).
https://rennlist.com/forums/997-foru...when-cold.html
Last edited by napoleon1981; 10-24-2019 at 10:42 PM. Reason: additional information
All year I'm fighting the exact same issue as you.
Makes me think there something in the base programming, as I know the Cobb doesn't impact the entire ecu.
Now, there are two of us with the same problem...
