P0300, 01, 02, 03 error codes
After 3 years with my '02 TT I don't freak out when I pop a code. However, the past two weeks I've popped the P0300-3 codes twice, always with a short burst of blinking CEL, followed by steady CEL. I haven't had a misfire for 2.5 years, since my last tuneup, so I'm a bit concerned. Especially by the blinking CEL.
I'm going to talk to my indy about it but would appreciate any advice.
oil, plugs ( coils, how long has it been? ).
The codes say one bank is misfiring. Along with checking plugs/Coils check your cam solenoid brackets too. It could also be a vacuum leak on that side.
What is entailed in replacing the cam solenoid brackets?
My car does not have a tune (yet).
It's been 16K miles since I replaced the plugs & coils (2.5 years).
I realize I didn't provide enough info, sorry.
The solenoid brackets are near the middle spark plug in each bank. They are held in place by two bolts.
if you have "cam position sensor" cels, that should show in the result of the OBD reader. at least they did for me. simple replacement. at 16k miles i wouldn't suspect plugs and coils as per my earlier post. GL. as to "brackets"? never had that one come up.
Another thing to consider, was any work done on the car just prior to the codes showing up?
