02 Turbo Tip leak, possible trans or other
With the color test on white paper I have two possiblities.
1- That is not transmision fluid. Trans fluid would be very red. So what is leaking is something else, maybe power steering fluid or engine oil? Check power steering resevior and engine oil level.
2- That is transmision fluid but it is completely worn out/broken down/burnt and should be replaced along with the trans filter.
My hunch is that it is power steering fluid.
If pentosin fluid, please clean it up real good. It is bad for rubber hoses and such. Also, it highly inflammable. Good luck!
The transmission mount breaks down over time causing movement of the transfer case. The transfer case thin paper gasket tears and starts leaking. Gaskets are available, not a bad job on a lift, torque higher than specs and loctite, 9 times out of ten, you will find finger tight or loose bolts. replace rubber donut on forward shaft flange, it will be hard or cracked. Good DIY on 996 forum, just have to search a little.
May be this is the one referring to a gasket at the end front end of the tip transmission. Very good informations on this thread....
https://rennlist.com/forums/997-foru...ing-fixed.html
also this one about the same gasket: https://www.6speedonline.com/forums/...e-gaskets.html
