Optimoly Ta (Aluminum paste)
The owners manual specifies that a thin coating of this stuff be applied to the wheel lug bolts. What is it? Anti-seize compound?
Where can you get it?
Are there alternatives like white lithium grease?
Thanks in advance for your help....
Keeper of the Truth
Yes, it is to prevent stick. It is a Castrol product but I am not sure who carries it. I am sure you can use any anti-seize compound, though.
Thanks guys...Can't even find that Castrol stuff anywhere after conducting an exhaustive google search. I guess I will pick up some Permatex Anti-Sieze... It has a blend of aluminum, copper and graphite in it. Man, I am just splitting hairs here trying to do everything just exactly perfect!!! Must be that Porschephile disease setting in... :-O
I use the permatex brand which you can find at any auto parts place. I also see the mechanics at my local dealer use the same stuff. You only need a little so buy it in the small tube. Jeff
![](http://www.986host.com/albums/ToolPants/anti_seize.jpg)
I have just order: Förch 6510 5020 Aluminium Grease Paste S426, 300 ml at 10 EUR,
will change the tyres next week and let you know about Forch, they apear to be a Porsche Racing partner
http://www.foerch-racing.com/
