996 GT2/GT3 Forum 1999-2005
Hoosiers R6 Vs Kumho v710
Old 04-03-2012, 12:13 AM
  #106
mkk62
mkk62's Avatar
so far i like kuhmos...drove for 5 yrs street tires, then r888's and nittos for 2, last yr running kuhmos ..dropped 1-2 sec sebring...but i only get 16 hc's i corded inside rears despite flipping tires ...making some alignment adjustments to increase tire wear..i am on my 3rd and 4th set and run the 245 squares / 305's rear as they are closer to stock heights...(wheel and tire) never had the delamination deputydog issue. gonna try hoosiers next...
Old 04-03-2012, 12:40 PM
  #107
Leigh2
Leigh2's Avatar
Originally Posted by blake
Hey Leigh-
So you are running "rounded" (245/35) up front, and "square" (305/30) in the rear. Kumho also makes a 245/40 in "square" up front...
Why did you choose the rounded over the square? Tire Rack has both available, so I am trying to decide...
Thanks,
-Blake
Blake,
I bought these last fall and they did not have the 245/35 in a square profile to match the rears. I called Kumho and they said no problem plus Tirerack put me in touch with another guy using the same setup on a 6GT3 and he was happy. I really wanted to go with the 245/35 to get more fender clearance in the front as the car is very low and I had already ripped out a fender liner with the 40 series Nittos....even with 800 lb front springs. Plus I thought the extra rake would help keep the front end down at speed. So far so good at both Chuckwalla and Spring Mountain as I was the fastest street car at both events.
Spring Mountain was running the 2.9 mile configuration which features a bumpy very high speed (130+) chicane. the car was still a bit floaty but not as bad as it was running the climbing S's at VIR with softer springs and the 40 series Nittos. I like the combination using the shorter fronts. Next I'm going to try the Hoosiers so that I can get a 255/35 front to see if the braking improves.
Peter
Old 04-03-2012, 12:44 PM
  #108
AudiOn19s
AudiOn19s's Avatar
Originally Posted by Leigh2
Blake,
Peter
No issues with ABS or anything due to the rolling diameter difference I assume?
Old 04-03-2012, 01:05 PM
  #109
996FLT6
996FLT6's Avatar
I think the round up front vs square would be better. If u put the 35 vs 40 together side by side the round is wider ie more contact patch which is good for our cars. Mike
Old 04-03-2012, 01:17 PM
  #110
deputydog95
deputydog95's Avatar
I ran mixed profiles in the kumhos out of necessity. That was all that fit in the 997 fitments. No issues. With that being said, I now have two stacks of hoosiers. Done with K's...
Old 04-03-2012, 02:07 PM
  #111
HiWind
HiWind's Avatar
Are H's similar prices to K's?
Old 04-03-2012, 02:09 PM
  #112
deputydog95
Yep, allegedly the K's last longer. I didn't have that experience. I don't find the K's nearly as fast either.
Old 04-03-2012, 02:23 PM
  #113
AudiOn19s
AudiOn19s's Avatar
huh, would have thought otherwise, good to know.
(my cheap *** will still probably just buy Nitto's and go slide around on them all season to keep costs down )
Old 04-03-2012, 04:09 PM
  #114
Leigh2
Leigh2's Avatar
No ABS issues at all...
Old 04-03-2012, 04:15 PM
  #115
AudiOn19s
AudiOn19s's Avatar
What alignment settings are you guys running with the Kuhmo's? Particularly those of you getting 30+ heat cycles out of them.
Old 04-03-2012, 06:26 PM
  #116
996FLT6
996FLT6's Avatar
Camber -3.2 front -3 rear toe in rear 0 toe front on stock rim size/offset caster ~ 8. This is driving to/for track. I flipped once and rotate side to side 4 times. 40 psi going to/fro track 30-31 hot on track. Mike
Old 04-03-2012, 07:02 PM
  #117
blake
blake's Avatar
Blake,
Peter
Awesome - thanks!
I'm a little confused... -3 rear toe, or -3 rear camber?
Thx
Old 04-03-2012, 07:33 PM
  #118
himself
himself's Avatar
Awesome - thanks!
Thx
Here is the translation. FWIW, -3 rear toe would be CRAZY. Mike didn't give you the toe-in amount. It's like .13' or so.
Toe in rear
caster ~ 8.
Old 04-03-2012, 08:10 PM
  #119
996FLT6
996FLT6's Avatar
^ what he translated : ). Mike
Old 04-03-2012, 08:22 PM
  #120
blake
blake's Avatar
Toe in rear
caster ~ 8.
Cool - thanks. My real intent was to drill down on the rear toe numbers that you guys are running. My current set-up has 0 in front, and 2-3mm per wheel in the rear. I am about to get another alignment after buying new tires (Kumho or R6s - done with MSCs), so wanted to double check...
-B
Quick Reply: Hoosiers R6 Vs Kumho v710
