LWFW + whatever else I need
U going 7.2 Rs flywheel ie 9lbs or 6rs/cup fw-11 lbs. U need to get the appropriate disc/pp to go with it. Pp mite be abit heavier pedal but u get use to it. U may also do the Rs pulley thing as well. 911 slow- chime in!!!! Mike
You don't "need" to do anything if your PP and clutch disc are low mileage and in good visual condition. However since you're in there and it's all apart the Sport clutch, PP, and TO bearing package from Sachs isn't that expensive....
Admin
Realistically speaking you need money.. : )
If you go for the LWFW make sure to upgrade the pulley.
Now regarding clutch and powerplates available it's up to you to decide how much money you want to spend and also to take into consideration the type of usage you have in mind.
Contact Gert or any other of the site sponsors for an offer.
LWFW
Pulley
Clutch
Anything else?
Here is my list for when I was going to do it, but didn't:
LWFW, clutch, pressure plate, pulley, throw out bearing, guide tube, bolts. [Also, be sure you get the right pressure plate.]
-td
-td
U be busy shifting gears : ). If u have cupbox then u need cup fw but they are probably the same as 6rs. Don't get 6 puck disc unless u plan to race- it's literally an off/on switch. Mike
